Please help with Tandberg TR2055 Offset Problem
Joined 2014
I am trying to repair a Tandberg TR2055 receiver. I have repaired several Tandberg receivers but this one has me stumped. I'm guessing that I am overlooking something obvious.
It arrived in non-working condition and obviously someone had done some work to it previously. I replaced all the electrolytic capacitors because Tandberg used Frako caps that are notorious for becoming leaky.
The problem: I'm getting almost the full positive rail voltage at the outputs and the base and emitter of the outputs. I'm getting about 26vdc at the input.
Both channels exhibit the exact same problem.
I have removed and checked each component on the board. I used a Peak DCA55 to test transistors and diodes. The only problem I could find were:
- The differential pair (Q801/803 and Q802/804) is a 2SC1583 (2 NPN transistors in a common case, with emitters joined). The Hfe on each pair was not closely matched (540/380 and 470/338)
- Both Q807 and Q808 are BD530. These showed as common cathode on my DCA55 but apparently this can be caused by very low gain. There are 2 other BD530s in the circuit and they tested normal on the DCA55.
I'm attaching a scan of the schematic for this amp board. Because both boards are exhibiting the same exact problem, I feel it must be something common to each. Since it had been hacked up previously, I've been trying to locate something done wrong but no luck.
I've spent way more time than this receiver is worth but I would sure like to know what I am missing. Any suggestions will be greatly appreciated.
  • TR2055 amp board.pdf
Joined 2014
26 volts on the input... Do you mean 26 volts on the left input side base of Q801/803? If so, what do you measure on the emitter(s) of Q801/803? What do you see across D801?
No, I'm getting 22 volts at the signal side of the input connector - J807. And about 20 volts at the shield side of that same connector. I'm getting about 35vdc at the emitter of Q801/803.
Joined 2014
You may be chasing a grounding issue. What do you see between the anode ('grounded side') of D801 and chassis?
I get negative 5.73 vdc at the anode side of D801. But it's the cathode that's connected to ground in my schematic. The schematic indicates there should be negative 15 v at that point.
I wondered if it might be a ground issue, but not sure where to find it. That would account for both channels having the same problem.
Joined 2014
I thought I'd report back on the solution of the problem.
First I located a solder bridge between base and emitter on Q803. But that didn't solve the problem. Q807/808 were showing as "common cathode diodes" on my Altas DCA55 tester. So I replaced these with MJE253 and all is well.
Thanks for the assistance with this one!
