Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Solid State Talk all about solid state amplification. |
Thread Tools |
#231 |
I just thought that the new 1900uf valve should be white. Unfortunately, I do not have a complete service manual �� there is only the beginning of the gle, the disassembly of the 27th is described and that's it.
just looked for new mellory for $ 60, so I thought to change them or something. I wonder how the replacement affects the sound do not know? |
#232 | |
P7 earth L1.678v. R1.7v P6 earth L1.734v R1.77v P6-P7 L3.45v. R3.46v P11 earth L0.02mv R0.02mv Constant output voltage R12.2mv L0.05mv What should I do can you explain in detail? I configured P11. I set the quiescent current to 20mv what's next? |
#233 |
Hi Mark,
Almost everything seems O.K. With 40mA per output transistor, this adds up to 160mA for 4 pcs. Between WH13 and WH14, you should measure 160mA x 0.22R = 35mV. The 20mV that you specified is that possibly between P16 and WH13 ? Have you also set Vreg+ and Vreg- to be within 0.1V in absolute value? When that's all done, there's normally nothing left to be adjusted. I am a bit puzzled why LS out measures 12.2 mV, that's a bit on the high side. With R3 you could bring this to zero volt if you like. To achieve that, take out R3 and replace it by a pot ,somewhat larger than 100k. Turn the pot until you have zero volt out. Take the pot out, measure it's value, and replace R3 with a fixed resistor of this measured value. Hans |
#234 | |
Hans, please tell me how to configure vreg+ vreg-? I read that you need to output a voltage of + - 65 volts. I will return to the 12.2 mv quiescent current later, first you need to alert everything. |
#235 |
With the two pots encircled in green adjust resp. Vreg+ and Vreg- to +/-63Volt, to within 0.1 Volt.
I assume that with the 12.2mA you mean 12.2mV, right ? Hans |
#236 |
Oops, forgot the image.
#237 |
Hans, I set up the quiescent current, but it was higher.
Hans but in the service manual to 27 it is written 65v and in the service manual 27.5 it is also written 65v. At what points should I measure + -63v, I do not understand. Yes, 12.3 mv in the other channel 0.02 mv Last edited by Mark levinson; 30th November 2020 at 07:14 PM. |
#238 |
Hans, I attach a screenshot from 27.5 and from 27. And so de in post 190 you wrote that the current is worth putting 39.6 mV.
Hans that in the end will be correct? 35 mV or 39.6 mV 🙂 |
#239 |
You are right, 65 Volt is the right value, sorry for the typo, good that you checked.
My earlier 180 mA was deducted from the ML23 with 45mA per transistor, but reading your manual, 40 mA was advised instead. But it does make hardly a difference, so either 35mV or 39mV is O.K. The +/- 65 volt should be measured at P1 and P4. Hans |
#240 | |
Vreg+ - 65v is set exactly ��. I also read in the service manual that the constant voltage at the output terminals is up to 30mv within the tolerance, so I should not worry? Or should there already be 0 mv at the output terminals at 27.5? Last edited by Mark levinson; 30th November 2020 at 08:46 PM. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
faulty Mark Levinson 33H Amplifier | 75andy | Solid State | 1 | 14th July 2018 02:47 AM |
Mark Levinson No. 535H 5 Channel Mono Amplifier | JohnRoy | Swap Meet | 1 | 10th June 2018 01:30 AM |
Mark Levinson ML-10 | ARTISAND | Analog Line Level | 1 | 25th October 2016 08:24 AM |
Mark levinson PLS-150 or 151 | lzhbts | Swap Meet | 1 | 25th April 2016 10:40 PM |
New To Site? | Need Help? |
