Pesky 120Hz Buzz / Hum From Speakers
Old 15th March 2019, 05:09 AM   #51
Evenharmonics is offline Evenharmonics  United States
Hum breaker resistor fixed it. I didn't want to modify the board but that's what it took. I had to cut / scrape off little bit of trace on the board and solder a 12 Ohm resistor across it. No more buzz / hum! However, now I hear faint radio reception from speakers. Now onto RFI cure method...
Old 15th March 2019, 11:01 AM   #52
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Are there RF filters on the inputs?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 15th March 2019, 11:33 AM   #53
tmuikku is offline tmuikku  Finland
Send a message via ICQ to tmuikku
Do you have proper electrical connection between all chassis panels? Sometimes paint / powedercoating prevents electrical connection between panels = poor faraday cage. How are the input wires again, shield goes to amplifier ground or chassis ground? Can't quite see from the picture if the input wires are coaxial or shielded twisted pair. If coaxial, ignore the question.
Old 15th March 2019, 04:27 PM   #54
No RF filter at the input yet. I will be installing one soon. One connection of 1nF ceramic cap between input ground bonding wire to chassis should be enough, no?
Input cables are coax shielded.
Old 16th March 2019, 01:38 AM   #55
kct is offline kct  Canada
kct's Avatar
1nF is way too much for my taste. You'd be killing the amps frequency response. Try 100p to 220p at most. Any cable you plug on the input will add additional capacitance to that.
Distortion ? What Distortion ? Wires ? What wires ? Screws ? What screws ?
Old 16th March 2019, 08:08 AM   #56
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
There are two filters that need to be installed for RFI
1. A 1-2 nF ceramic cap from the signal ground right at the input connectors to the chassis at the point of entry. The cap leads should be no more than 1 or 2 cm long - the shorter the better
2. A series mode filter Pi in line with the signal plus. I usually use 220 Ohms and 1 nF or 1 k and 220 pF. The Both work very well. The cap is returned to the signal ground and not the chassis ground. Ideally you want this also at the input connector(s) but more often than not they end up on the amp module PCB
This should kill any RFI and will have no effect on the audio signal.
Old 16th March 2019, 01:43 PM   #57
I've heard radio reception through my active speakers (Behringer Truth 82030A for desktop computer) but cured it with ferrite bead around the line level cables which is located very close to vent openings at the back cover of speaker. Can the same work in this case too? I happened to have a few spare ferrite beads.
Old 16th March 2019, 06:09 PM   #58
Bonsai's Avatar
Yes, ferrite beads work well - that’s another weapon in the arsenal. If you have some try it. If that does t work, do step 1 and 2 mentioned earlier.
Old 17th March 2019, 01:16 AM   #59
All done! No buzz / hum or radio reception.
Images are HBR and ferrite bead installed. Thank you all for the help.
Pesky 120Hz Buzz / Hum From SpeakersHide this!Advertise here!
Buzz in speakers radiator2 Solid State 3 15th December 2014 01:32 PM
120Hz buzz in chipamp output caused by transformer? djnebs Chip Amps 12 25th June 2014 02:36 PM
Buzz/Hum from Audiosector LM3876 board itself - no buzz in speakers dakku Chip Amps 4 12th April 2014 02:51 PM
Melos triode and computer as source: BUZZ BUZZ BUZZ zigo3 Tubes / Valves 4 28th November 2007 02:11 AM
5dB dip at 120Hz in my speakers? cjv998 Full Range 12 21st September 2007 11:10 AM
Copyright ©1999-2019 diyAudio
