Pesky 120Hz Buzz / Hum From Speakers
Old 27th January 2019, 09:04 PM   #11
Evenharmonics is offline Evenharmonics  United States
Originally Posted by Mark Whitney View Post
Where is the second channel? You are not going find a solution without looking at the complete layout.
It's basically a mirror image of what I already posted. See attached.
Old 27th January 2019, 10:00 PM   #12
Mark Whitney is offline Mark Whitney  Netherlands
Mark Whitney's Avatar
Here you can see the ground loop and the ground loop area. What are you using as a source and does it also have PE connected? What type of cable are you using from input to pot to amp?
Regards Mark.
Old 27th January 2019, 11:05 PM   #13
Looks like I need to break the ground loop.
For now, I'm using USB sound card Focusrite Scarlett Solo as preamp and playing music files from my computer. It will eventually be used with my Onkyo preamp in other room.
Line level cables inside are RG-179 which works well for my other amp & preamp builds.
Old 28th January 2019, 12:02 AM   #14
voltwide is offline voltwide  Ireland
Without explicitely looking at the details of your wiring - a 120Hz sawtooth is a strong indication towards bridge rectified 2x60Hz current spikes inducing quite small but audible voltages in ground loops.
tuby or not tuby, that is here the question!
Old 28th January 2019, 12:56 AM   #15
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
You need to isolate the source.
Disconnect anything external from amp and short amp input.
That will tell you if it is the amp or connected equipment causing hum.
If its the amp it could be a ground problem, the amp should have star grounding.
I have found with some amps the power supply hum can get into the amp front end so I always decouple the amp front end from output stage with RC.
Keep input wires as short as possible and away from transformers.
Input wire should be screened if possible.
PCBCAD51 download or CDROM 2019 version out now http://www.murtonpikesystems.co.uk
Old 28th January 2019, 05:10 AM   #16
One down, one to go!
I found the culprit for buzzing when no input is plugged in. It was accidental coupling of input plug with the chassis. Shown in the attached picture are TRS input plugs which I forgot that they have metal threads and mounting nut (I recently finished another amp with TRS that has plastic threads and nut). It was electrically connecting chassis and input shield wire. I removed it and now it's dead silent when no inputs are connected.
Now onto puzzle #2. When the input is connected, there is faint buzzing from speaker, though not as loud as it has been, it does get slightly louder if I turn the volume up all the way.
Old 28th January 2019, 10:40 PM   #17
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Good that you found the ground loop caused by the connectors shorting to the chassis. When the input connectors are shorted to the chassis and you have the PSU 0V tied to the chassis elsewhere, you get a loop. The loop currents flowing in the chassis metalwork can be quite high. The rule is you can have one and only one connection from the amplifier PSU 0 V to the chassis metalwork.
At the back of the presentation (slide 68 and slide 69) is a short debugging guide to help determine whether the problem is common impedance coupling or an earth loop.
I see you have mounted your input conn3ctors close together. You should bond the signal returns together. This traps internally generated cross Chanel ground loops inside the amplifier.
Does your amp have hum breaking resistors (HBR) ?
Looking at your diagram, Mark has highlighted where you have large loop areas. Power cables to the amp modules must be twisted together. AC from the transformer to the rectifiers/PSU board must be twisted together.
Twist the speaker hot and return together from the amp module to the speaker terminals.
See slides 61 to 63 for info on how to route the input cables - again, it’s all about minimizing the total loop area.
Quick tip: always bring your power connections onto an amp module together - avoid spreading them out as this creates a large loop area on the PCB.
Old 29th January 2019, 12:00 AM   #18
Thank you, Bonsai, for those articles.
It's silent without line level input connected but the buzz/hum returns when they are connected, each speaker per each input. So far, I've tried HBR between input shield wire and amp board ground "in" but the noise level increased. It sounds more like 60Hz hum than 120Hz buzz. I bonded input jack ground and that helped slightly but buzz/hum is still there when input is connected.
Old 29th January 2019, 12:06 PM   #19
Bonsai's Avatar
Ok. It’s very important to note that you cannot simply put a HBR resistor in series with the shield connection. You will make it worse by doing that, because the noise loop current flowing through the resistor is in series with the signal.
See slide 37 on how to do it correctly. When it’s done the right way it will attenuate the noise signal and reduce the noise loop current. A 20 dB improvement is usually what you can achieve.
Note that when I mentioned input jack bonding, it just means ‘connect the two signal grounds together where they enter the housing - do not run any separate wire to the 0V on the PSU!
The input cable routing to get rid of the hum is critical. See slides 61 to 63. If you just run the cables directly from the input jacks to the amp modules (shortest route) you are probably creating a huge loop area inside the amp. Run the two cables together to the fist amp module, and continue the second input cable to the second module. You may well find that if you run it back to the PSU alongside the 0V return, and from the PSU alongside the 0V to the second amp module, you get the best result - you will need to experiment a bit to get the best location though. This is where I recommend the ‘headphone trick’ - See slide 65 and 66.
Don’t forget to rotate you transformer +- 60 degrees to find the noise null point as well.
Old 29th January 2019, 12:12 PM   #20
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Originally Posted by Bonsai View Post
Ok. Itís very important to note that you cannot simply put a HBR resistor in series with the shield connection. You will make it worse by doing that, because the noise loop current flowing through the resistor is in series with the signal.
I've done that as a temporary "fix" on one channel only, and has done the job, shown the problem to be a cross channel loop?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Pesky 120Hz Buzz / Hum From SpeakersHide this!Advertise here!
Buzz in speakers radiator2 Solid State 3 15th December 2014 01:32 PM
120Hz buzz in chipamp output caused by transformer? djnebs Chip Amps 12 25th June 2014 02:36 PM
Buzz/Hum from Audiosector LM3876 board itself - no buzz in speakers dakku Chip Amps 4 12th April 2014 02:51 PM
Melos triode and computer as source: BUZZ BUZZ BUZZ zigo3 Tubes / Valves 4 28th November 2007 02:11 AM
5dB dip at 120Hz in my speakers? cjv998 Full Range 12 21st September 2007 11:10 AM
Copyright ©1999-2019 diyAudio
