Plate amp repair question
Old 11th January 2019, 11:16 PM   #11
llwhtt is offline llwhtt  United States
Usually if they are shorted it doesn't matter if they are disconnected or not. Are they both the same or is one of them a IRF530? There may be some collateral damage upstream so make sure you check for more bad parts.
Old 11th January 2019, 11:28 PM   #12
Bret burrill is offline Bret burrill  United States
Bret burrill's Avatar
The big capacitors are in the way of the other one so I can't read it. I tested the other from the underside of the board and it has continuity between 2 and 3 also. Is it possible to do this job without a special type of soldering iron?
Old 11th January 2019, 11:31 PM   #13
The only real danger in dealing with any type of FET is static electricity, it doesn't take much destroy then when they are NOT in the circuit.
Old 11th January 2019, 11:43 PM   #14
OK good to know. Thank you
Old 12th January 2019, 06:02 PM   #15
I just ordered the mosfets. If there is something else wrong with this amp, could it ruin the new mosfets right away?
Old 12th January 2019, 06:09 PM   #16
yep.
Old 12th January 2019, 06:12 PM   #17
Figured as much.
Old 13th January 2019, 06:19 AM   #18
Ian Finch is offline Ian Finch  Australia
It may not matter to you at this point but there are several cheap sources of IRF530/9530 and similar audio-compatible mosfets, who supply parts with an "N" suffix, as in IRF530N, 9530N. These types are modified for switching applications and despite assurances, they aren't as good for audio as the original type. Chinese suppliers usually ignore the difference and even their own advertising by sending you the switching type regardless. Watch that any local source isn't just reselling the N type too.
If only I had listened....
Old 13th January 2019, 07:12 AM   #19
Thanks. I started a thread in the 'parts' forum before buying them today. These are what I ended up ordering:
IRF9530 Vishay / Siliconix | Mouser
Plate amp repair questionHide this!Advertise here!
Dayton SPA250 Plate Amplifier repair help nixit Subwoofers 43 27th June 2018 03:54 AM
ads power plate 120 repair elchino10 Car Audio 10 28th April 2016 01:34 AM
Klipsch KSW15 plate amp repair. internecine Solid State 11 23rd September 2014 07:29 PM
plate amp repair/replacement foxes Class D 1 14th September 2014 05:07 PM
Subwoofer Plate Amp Repair running123 Solid State 7 2nd November 2013 06:25 PM
Copyright ©1999-2019 diyAudio
