Book question - Randy Slone - High-Power Audio Amplifier Construction Manual
Old 11th January 2019, 05:08 PM   #1
CallAnAudible is offline CallAnAudible  Canada
Question Book question - Randy Slone - High-Power Audio Amplifier Construction Manual
Hi all,
First time poster here. I searched this forum for info on the second ed. of the book and learned it was never released.
Is there still value in buying the first ed. given it is circa 1999? Or are there better books for construction projects? BTW, I am planning to purchase the new ed. of Bob Cordell's book when it's released in May.
My goal is to get back into audio electronics which was a hands-on hobby many years ago for me.
Thanks,
Rob
Old 11th January 2019, 05:37 PM   #2
jwilhelm is offline jwilhelm  Canada
These days you are better to pick a design from a forum such as this from a reputable designer. The forums offer fast support for any issues that may arise.
I own a copy of Randy Slone's High Power Audio Amplifier Construction Manual. It has many "tested" designs to choose from. I did a quick google search on his best design and found a bunch of posts here at DIYAudio saying the design was flawed and couldn't work. His math and theory are good but be careful what you want to build.
https://www.vzaudio.com/
Old 12th January 2019, 02:46 AM   #3
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by CallAnAudible View Post
...Is there still value in buying the first ed. given it is circa 1999? ...
I find much value in reading Electronics magazine back to 1930 (I'm on 1960 today). I happened across a tube-type which "could" be of value in a future Venus-rover (runs happy super-hot). But I'm strange.
If you must have only the newest info, Twitter is always fresh.
Old 12th January 2019, 04:13 AM   #4
Dave Zan is offline Dave Zan  Australia
... I searched this forum for info on the second ed. of the book and learned it was never released...
Hi Rob
I have the first edition, picked up from Better World Books (an excellent source for second hand books). Cordell is better (the second edition will have construction details, so even better) but a copy of Slone is worth a look if you can find one cheap. As JWilhelm says, I would NOT use Slone for actual circuits, some have problems, do not build unless you read the discussion in DIY about this. Better to use circuits from here. Damir's (DadoD) are excellent. Toni's (ASTX) if you are ambitious (they tend to more power and cost) Both are skilled and very helpful, can provide boards, there are others but that's where I would start.
Best wishes David
Old 12th January 2019, 11:29 AM   #5
5th element is offline 5th element  United Kingdom
5th element's Avatar
Slone's book is better off giving a miss. Although interesting and entertaining to read it does not go into enough detail and has errors. The errors are usually in providing some circuits that do not actually function the way they are intended to. While the lack of detail is attractive to beginners it gets a little confusing when you are wanting more and want further knowledge.
The PCB layouts also do not allow the circuits to perform to the ability that they are capable either so you are better off not building them.
Having said all of this I was once a real rookie, read his book, and using his PCB layouts built some of his circuits. I had fun. One design worked well, the blameless amp, the other one did not.
I have since bought Self's book on amplifier design and it's in another league entirely. This is a good thing but also a bad thing. If I had bought Self originally it would have been too much and offer too little in terms of ready made designs. Slone got me building my first amps, so in that case his book was a complete success.
This was some 17 years ago now and things have changed. There's far more available online now to get you started!
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 14th January 2019, 01:45 AM   #6
Thanks for the advice everyone. I think it makes sense to use designs that are known to work especially since I’m just getting going.
Old 14th January 2019, 06:40 PM   #7
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
if the reader is determined to learn something and is not easily discouraged/derailed/distracted, a book with some unknown errors can be a great learning tool.
Think about how many mistakes that you "discovered" and solved on your own have you ever repeated versus the mistakes that required no pain and bloodshed (i.e. the answer was spoon-fed) to solve?
I'm just sayin' .....
mlloyd1
Old 14th January 2019, 07:41 PM   #8
mlloyd1
Ha! Good one. But I think I'll start slow. I think I'll make my fair share of mistakes all by myself!
Book question - Randy Slone - High-Power Audio Amplifier Construction ManualHide this!Advertise here!
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 47 12th April 2018 03:47 AM
Book by Randy Slone filenet Solid State 2 17th September 2015 07:45 PM
HEEEELLLPPP : M. Randy Slone Mirror Image Topology Construction - Troubles Olivier73 Solid State 488 28th July 2015 09:27 PM
High-Power Audio Amplifier Construction Manual Krisfr Solid State 3 12th December 2010 07:01 AM
Are those worth buidling!!! -- > Randy Slone book.. JinMTVT Solid State 0 12th July 2004 05:26 AM
Copyright ©1999-2019 diyAudio
