SR5008 Thermal protection fix
Old 11th January 2019, 03:54 PM   #1
angelman is offline angelman
Post SR5008 Thermal protection fix
My Marantz SR5008 receiver was shutting down due to a thermal protection error. It took me a long time to properly diagnose this failure, because it was sometimes shutting down after only a few seconds, sometimes after a couple of minutes, and sometimes it was functioning properly for a few days.
You can manually bypass the protection circuitry by pressing power+display+status+sound mode. 'Protection pass' is displayed, and everything was working fine. However, this is not a solution, so I tried to figure what the problem was by disassembling the amplifier-radiator module (7ch amplifier).
I measured the PTC resistors, and there was some variation, but I was not sure if replacing them would solve the errors. After reading another post on this forum about a similar amplifier (denon x1200w), I decided to disable the thermal protection for ever.
See attachment where to break the lines on the PCB of the amplifier module. Caution: you have to break/stop lines on both sides, so you have to desolder the power transistors. Of course, your amplifier is not protected against overheating, so only perform this operation if all other options failed!
After this has been done, no thermal protection errors, and my amplifier has been fixed!!
If you have any questions please send me a PM.
Old 5th February 2020, 05:36 PM   #2
PeterCetera is offline PeterCetera  Brazil
Default Marantz SR5009
My SR5009 ... is in protection mode (thermal A) ... can you help me?
  Reply to this post
SR5008 Thermal protection fixHide this!Advertise here!
Best way to implement thermal protection? mightydub Solid State 5 2nd October 2009 11:02 PM
GFA 535 II thermal protection led lit kheper Solid State 1 23rd June 2009 04:01 AM
after 3 yrs. thermal protection kicks in on 2 of 4 ch. slicey Car Audio 5 10th September 2005 10:47 PM
OPA541 w/ or w/o thermal protection? JojoD818 Chip Amps 17 4th January 2004 11:15 AM
Thermal Protection Circuit cm961 Parts 2 21st January 2003 04:19 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
