Referenz - high-quality low-cost diy-friendly amplifier
Old 11th January 2019, 07:39 AM   #51
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
Originally Posted by thimios View Post
Small progress, but many caps wrong named.
Do you mean - the schematic and the PCB's reference numbers don't match?
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 11th January 2019, 07:42 AM   #52
thimios is offline thimios  Greece
Yes,but no problem.
The problem now is some missing parts...
I have a suggestion for the next version.
Led and transistor(CCS) in thermal contact.
Old 11th January 2019, 07:43 AM   #53
vzaichenko's Avatar
Yes,but no problem.
I will check anyway
http://vzaudio.com/
Old 11th January 2019, 05:53 PM   #54
Close to the finalize.
Still dirty.
Old 11th January 2019, 05:58 PM   #55
jwilhelm is offline jwilhelm  Canada
You better hold off on testing that Thimios. There is a mixup in the component designations. You may need to move some resistors around.
https://www.vzaudio.com/
Old 11th January 2019, 06:14 PM   #56
Here's the schematic that matches your board. This has the incorrectly drawn servo connection.
Old 11th January 2019, 06:47 PM   #57
The flying resistor inside the black tube is the 56k.connected on the input transistors bases.
Is it any other resistor rearranging?
Old 11th January 2019, 06:57 PM   #58
It looks like the resistor and diode numbering matches, just the capacitor numbering was wrong.
Old 12th January 2019, 06:05 AM   #59
rhythmsandy is offline rhythmsandy
Just replied above At 12mA it drives them fine (local heatsink is required for the drivers for keeping their temperature relatively constant). Expected rails are +/-50...55V DC.
You are super..! im still confused how its possible though..! ksc3503 delivering 12ma at what ambient temperature. Why cant we just stepup with higher capacity transistors? like 2sc5171 or 2sc4793? I believe it can be done though. Any thoughts of mosfets gate protection like adding some zeners in the OPS?
Old 12th January 2019, 08:24 AM   #60
vzaichenko's Avatar
At 50V rails, each driver dissipates 12mA * 50V = 600mW, which is fine for TO-126 transistor, equipped with a local heatsink. The drivers run moderately warm, no problem. A big advantage of 3503/1382 - they are very "fast". Those are the Video transistors with fT = 150MHz and low capacitances.
More powerful drivers are normally "slower" - that may require some additional compensation. If you have read my post #47 carefully - I have mentioned there I even used 0381/0302 as drivers. In any case, with the higher fT you will require the lighter compensation and the higher performance.
http://vzaudio.com/
Referenz - high-quality low-cost diy-friendly amplifierHide this!Advertise here!
A High-Quality, High-Power Headphone Amplifier gdan Headphone Systems 10 1st February 2016 02:08 PM
Where to order a high quality low cost SMT stencil? Fusion916 Solid State 5 29th November 2015 02:11 AM
Made in China,low cost,high quality,electronic components,power supply etc hang Vendor's Bazaar 1 16th September 2009 01:44 PM
Copyright ©1999-2019 diyAudio
