NAP250 clone
NAP250 clone
Old 5th November 2019, 10:23 AM   #111
Mark Tillotson is online now Mark Tillotson
Use transparent solder mask perhaps?
Old 5th November 2019, 11:55 AM   #112
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
NAP250 clone
Originally Posted by Iain McNeill View Post
... Copper is a fairly active metal and will corrode quite quickly...
Even without a solder mask the copper still has a protective coating of tin.
I've repaired a bunch of little amplifier circuit boards for the coolant level and outside temperature sensors in 1960s and 70s RR/Bentleys that have been sitting around in British Isles humidity for nigh on 50 years. 90% of the time it's the diodes that fail, with the odd transistor or rivet that attaches the pins to the board. But I've never had an issue with oxidation on the board itself. (I do spray the entire assembly with cellulose lacquer after replacing the diodes and transistors, but that's just because they're going back out in the weather again.)
Yeah, I actually tried that, but sadly it kicks you out of the pooling and the board cost goes way up.
Old 5th November 2019, 12:10 PM   #113
JeffYoung's Avatar
NAP250 clone
Originally Posted by avtech23 View Post
Would it be worth opening a dedicated group buy thread?
I'd be interested in 2 amp and 2 inverted regulators but dependant on price.
I didn't originally because I didn't want to get flooded with 70 subscriptions like with my J2 boards. But this appears to have much less interest, so I think I will put up a GB thread....
[Edit: thread is up: NAP250 amp boards & regulator boards ]
Old 7th November 2019, 01:08 AM   #114
gary s is offline gary s  Australia
Hi Jeff,
Any clues as to where to source the BC239C input transistors and either of the output TO3 metal can types you have on the schematic. Not stocked at Mouser. All the other transistors are in stock in qty at Mouser , so no problems with those.
Or, have you further alternatives, should not be too hard for the inputs TR1 and TR2. Maybe the output stage TR11 and TR12 need to be as close to original design semi's as possible.
Look forward to your thought on these devices. Also posted this in your GB thread.
Also, have you posted the schematics for both regulator design's?
Gary..
Report Post
Old 7th November 2019, 01:17 PM   #115
JeffYoung's Avatar
NAP250 clone
Hi Gary,
I replied on the device questions in the GB thread.
I probably posted both regulator schematics, but it's easier to do it again than to find them.
Julian's regulator:
NAP250 clone-youngreg_schematic-pdf
My inverted version:
NAP250 clone-youngreginv_schematic-pdf
Jeff.
Old 7th November 2019, 08:35 PM   #116
Thanks for the schematics again Jeff.
Gary..
Old 8th November 2019, 02:12 AM   #117
Iain McNeill is offline Iain McNeill  United Kingdom
diyAudio Moderator Emeritus
Iain McNeill's Avatar
NAP250 clone
OK, good - you have a protective layer.
I did a lot of home etch boards back in the day and they did not hold up well, even with good post etch cleaning. Maybe city air quality has an accelerating effect but bare copper isn't a longevity play.
Old 8th November 2019, 12:17 PM   #118
JeffYoung's Avatar
NAP250 clone
I have some cold tin plating solution for home etching, but I got on so poorly with the iron-transfer part that I've never tried it.
City air definitely greatly speeds the oxidation of copper roofs, but I'm not sure how much of a part rain plays in that.
Old 8th November 2019, 01:23 PM   #119
stanislav1957 is offline stanislav1957  Russian Federation
I don't understand why you don't use the Darlington amplifier voltage or kaskadno connection !
Old 8th November 2019, 03:01 PM   #120
JeffYoung's Avatar
NAP250 clone
Hi Stanislav1957,
Did you mean to post that to a different thread? It doesn't look anything like a NAP250 (other than the LTP and VAS current sources sharing the same reference)....
Jeff.
NAP250 cloneHide this!Advertise here!
NAP250 MOD amplifier 80W by LJM stepik Solid State 3 13th September 2018 04:05 PM
FS: Naim NAP250 power amp DubbLinn Swap Meet 2 15th May 2013 06:19 PM
convert a NAP180 into a NAP250 fantes Solid State 2 11th November 2008 06:56 PM
Naim NAP135 vs NAP250...which one? Minh Solid State 60 11th March 2007 08:05 PM
Help with Naim NAP250 colin betts Solid State 3 25th November 2001 12:29 PM
Copyright ©1999-2019 diyAudio
