Adcom GFA 555/GTP 400 issue
Old 17th December 2018, 09:37 PM   #1
almostdeaf is offline almostdeaf  United States
Default Adcom GFA 555/GTP 400 issue
Hello all, I've had these units stored away for a few years now. I recently got them out to run some PA SDA 2Bs I recently bought and I've run into a volume issue. I'm spinning vinyl with this set up, and at any volume below half way, the sound will fade in and out in each channel, independently from each other. If I turn the volume up past the halfway point, the channels will lock in and stop fading. I tested on a different pair of speakers and got the same results. I also tested with a different TT, and I get the same fading problem. Anyone with ideas?
Old 17th December 2018, 09:56 PM   #2
rayma is offline rayma  United States
First, try cleaning the volume control. If that doesn't help, clean the other switches and controls.
This is very good: CAIG DeoxIT D5S-6 Spray 5 oz. with Perfect Straw
Old 11th January 2019, 02:48 PM   #3
Just wanted to follow up and say the problem was a bad cap in the right channel. Had it fixed, and she's singing like a songbird now. Love this amp, and my PAs do too.
Adcom GFA 555/GTP 400 issueHide this!Advertise here!
Adcom GFA-7000 Amp Issue (Need Advice) tyger23 Solid State 11 21st January 2017 08:28 AM
Adcom GTP-500 II Phono section issue Drewgy Solid State 12 30th January 2016 08:13 AM
Adcom GFA-555 II issue... Mystery123 Solid State 18 20th January 2014 06:07 PM
My mistake. Adcom amp issue. Adcom535 Solid State 5 10th April 2012 07:14 PM
Adcom 565 - Hum issue a.wayne Solid State 0 19th February 2009 06:14 AM
Copyright ©1999-2019 diyAudio
