The Technics SU-V9 , i had help with friends and is working perfectly, like a dream, sometimes there is a bit of trouble with one channel, i suspect, the connector, as moving it back and forth returns to normal.
It would be nice to have a spare relay - running out at Mouser discontinued part i think ,not with much confidence it is
HC2-HP-DC24V-F Panasonic Industrial Devices | Mouser Australia
Old part is:
6A60VA AP39421 = HC2-P-DC24V-Y2 , it is 8 pin
My black Technics SU-V8 ( silver V8 seems fine). Sound is low sometimes on fire up and static - could be the controls could be the relay
I am not sure what relay would be a replacement?
Looking around the forum, a member had a Technics SU-8099, part number matched the V8 so i assume is the same.
7A 1/6HP125.250/AC 3A30VDC HC2a-P-DC24V it is 8 pin
Unlike the V9 there is an 'a' in the serial number, could it be formA or 2formA
Would the above part suit it and the v9 as as spare relay
Old part is:
Hi MaccAu,
I know this is an old post but I came across it googling replacements for the Panasonic HC2 relay.
I believe Omron's MY2-02-DC24 would be a suitable replacement for it.
MY2-02-DC24 Omron Automation and Safety | Mouser
I am going to be ordering some for my SE-9060's and we'll see how it goes.
Figured I'd post here in case someone else was googling!
