I purchased 3 batches of these chips from Ebay (different sellers), 30 pieces in total, and tested all the boards I made (5 so far), and the chip
was working correctly, including DC detection. That was 4 years ago.
Thanks for confirming. I tested all ICs again with different set of passives , both AC failure and DC detection are working now. I think the capacitor connected on Pin 2 was faulty. Ordering more of them from AliExpress
You can buy from anywhere and if required can change relays for better quality contactsplease do someone have a good source ? for a UPC1237 Speaker protection board which is not garbage
thanks, difficult to choose version as there is plenty
UPC1237 Double Parallel Omron Relay ???? Horn Speaker Protection Board AC 12V-24V
https://www.ebay.com/itm/164957415034
https://www.ebay.com/itm/264663559721
https://www.ebay.com/itm/403273875050
other relay
https://www.ebay.com/itm/394240478134
other relay
They will last for many years , provided those are genuine omron relaysUPC1237 Double Parallel Omron Relay
- UPC1237 Speaker protection board: Current requirements
