NAD 216 red protection problem
Thread Tools
Old 21st November 2020, 09:19 AM   #71
Audio Service is offline Audio Service  United Kingdom
Great to hear you have repaired your Amplifier.
Old 8th April 2021, 03:24 AM   #72
Ben99 is offline Ben99
First, say Thanks this is a great forum. thanks, Sqeek, Ylli, Audio service, and everyone for the post.
I have a NAD214 of the amplifier. My amplifier had the same problem. The amplifier was in protection. I knew the model close to Nad216, just different the output power. I study all the feedback about check the amplifier's Led red in protection. I test
IC202(TA7317P)
Pin1 0.68-0.69V
Pin 2 0 V
Pin 3 0V
Pin 5 0.78V
Pin 6 50 V ( the relay turn on or off, I don't know)
Pin 7 0.04V
Pin 8 0.38V
Pin 9 0.44V
Compare the TA7317P data
Pin 8 and Pin 9 have a problem. the normal voltage is Pin 8, 8V, and Pin 9, 3.1V.
Test:
D213 15V
D214 15V
R244 -55V
R243 55V
Based on previous the post mentioned the Pin 8 OF IC202 that offers the protection signal.
I thought the relay or TA7317P was broken. I purchase the parts after I wish I can find out the problem. I am not an Electrical Engineer。
/Users/foxben/Downloads/IMG_2511.HEIC
/Users/foxben/Downloads/IMG_2512.HEIC
Old 8th April 2021, 06:39 AM   #73
Vrystaat is offline Vrystaat  South Africa
I had a problem with a 214 with intermittent problems. I turned out to be the tarnished connectors between the Power board and one of the amp boards. My amp had plugs that made bad contact. Some people remove the plugs and solder the ribbon cable directly to the amp boards. Maybe it your problem as well.
Jan
Old Yesterday, 07:34 AM   #74
thank you for your response. I have been pulled out the plug and put it in several times, and tested the signal with the L-channel and R-channel. I am sure not the plugs problem.Click the image to open in full size.
Old Yesterday, 08:10 AM   #75
AllenB is offline AllenB  Australia
AllenB's Avatar
Ben99, your posts are currently under moderation as you are a new member. There is no need to post multiple times, it will just take a little time for them to show up.
  Reply to this post
NAD 216 red protection problemHide this!Advertise here!
Thread Tools
Protection problem, PIC controller. rrae Car Audio 5 22nd May 2017 06:16 PM
NAD c350 protection module problem hostarn Solid State 17 19th January 2015 05:58 PM
Problem with protection circuit NicolaTeam Car Audio 7 11th July 2014 04:12 PM
Speaker Protection Problem danbaxtr Multi-Way 11 15th February 2011 06:24 PM
Onkyo Amplifier protection problem ricochet Solid State 1 13th August 2008 10:00 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
