R16 and R17 measure 415 mV.
BC546 and BC556 are B grade.
KSC3503 is D grade.
KSA1381 is E grade.
However with Onsemi KSA1220 KSC2690 it seems to me improved. BD139/140 weren't as good.
KSC3503 is D grade.
KSA1381 is E grade.
Oloppolo, your amp looks like it’s ok. R16 and R17 are a bit high, but I think you are ok to go. Output current is 463mA per pair which is ok.
You now need play some music through it and wire it up in its final configuration. If you have any hum problems, come back here or PM me to help to solve it.
For those wanting to build a kx Amp, please go to this thread
New Hifisonix kx2-Amplifier
This is the updated and improved kx2 Amp 28 W class A, low distortion wide bandwidth CFA.
- Hifisonix kx-Amplifier
