Hifisonix kx-Amplifier
Thread Tools
Old Today, 04:32 PM   #411
Rallyfinnen is offline Rallyfinnen  Sweden
I always had this (RC to GND on the back of the PCB's) since I first tested the boards on the bench.
Old Today, 05:47 PM   #412
polsol is offline polsol  South Africa
Originally Posted by Bonsai View Post
Polsol/Rallyfinnen,
can you solder directly on each module PCB a 10 Ohm resistor in series with a 0.1uF cap from the amplifier side of the output coil (ie the side closest to the 0.33 Ohm emitter degeneration resistors) to the 0V where it comes in on the PCB. You need keep the leads as short as you can make them.
Can you then tell me what you see on your scope.
I don't have a spare 10 ohm 5W resistor handy but can pick one up tomorrow.
Would connection using the ZN output and and OV tabs on the kX board suffice or do you want it closer?
Tony M
Old Today, 06:15 PM   #413
Bonsai is online now Bonsai  Europe
Bonsai's Avatar
From the ZN to the 0V should work well - you must just keep the connections short.
  Reply to this post
Hifisonix kx-AmplifierHide this!Advertise here!
Thread Tools
Boss NXD3500 car amplifier hooked to an Onkyo 7.2ch home amplifier Evolver Class D 1 13th March 2020 11:48 AM
Hypex SMPS400 + 2x UCD180 wiring (DC error, Auto Amplifier Enable, Amplifier Standby) maxw Class D 48 26th May 2017 07:47 PM
hifisonix small signal class a? mlackey Headphone Systems 1 1st January 2016 03:16 AM
Motional feedback amplifier based on Philips 40 wats amplifier 1970s sanbadgujar Solid State 14 13th October 2013 02:35 PM
JLH Chiarra or Hifisonix Class A buffer? MondyT Headphone Systems 2 30th January 2013 05:14 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
