Hifisonix kx-Amplifier
i was looking at this KX amplifier, very interesting...i'm not very experienced but i would like to gather some information...
first of all: many thanks to the designer for sharing all the details and instructions!!!
How about matching the transistors, do these need to be bought a lot and be matched?
As far as concerning for;
the output transistors NJW3281/NJW1302.
the driver transistors KSA1220A and KSC2690A
the TO-92's
or just buying the nessecary quantity and the right type?
thanks in advance and greetings!
www.hifisonix.com
Joined 2003
ripple on the main output rails of a few volts under load makes no difference if the amp's VAS stage is properly regulated.
The kx-Amp PSRR without the optional cap multiplier PSU is >70 dB at LF and better at HF - typical figure for a CFA. With the optional cap multiplier PSU, its about 30 dB better.
VFA PSRR is usually about 20 to 30 dB better than a CFA.
Joined 2011
Here's what I see on Saturday at 11:13 in San Francisco. That's 19:13 in London.
_
