Adcom GFA-5800 which capacitors?
Old 31st October 2018, 03:19 PM   #1
Gogo6969 is offline Gogo6969
Smile Adcom GFA-5800 which capacitors?
I recently got an Adcom GFA-5800 for $50. I've used it as a subwoofer amplifier in my surround system. Then a friend told me that he has bought a new McIntosh and installed it as the stereo amp in his system - and that he was so in love with the result.
A long time ago I was also into high end fidelity but not anymore because of no time... so i thought. Until I hooked up the 5800 as my stereo amp (like my friend with his McIntosh) - and I was blown away. I have not heard music that good since I was young.
I found some smaller problems, a broken fan, a blown resistor and repaired it.
Now I'm thinking about new capacitors... the hifi bug got me back :-)
I would like to ask if someone can tell me which capacitors I should replace and where I can buy new ones or similar ones?
Every help is much appreciated.
PS: I do have the GFA-5800 service manual if needed.
Old 31st October 2018, 04:04 PM   #2
DF96 is offline DF96  England
Which capacitors are faulty? Replace them.
Old 31st October 2018, 04:14 PM   #3
DreadPirate is offline DreadPirate  United States
DreadPirate's Avatar
Apex Jr, one of our vendors here, may carry something you can use for the main filter caps.
I would give it all up for just a little bit more...
Old 1st November 2018, 02:53 PM   #4
Thanks for the hint.
Anyway... I would like to ask again if anyone has experience with replacing all the caps in a GFA-5800?
Old 8th November 2018, 11:17 AM   #5
Jose Jimenez is offline Jose Jimenez
Default Muffed...
If it sounds good why do you want to be replacing parts? I have a 5800 amplifier also but nothing inside has been changed or altered. I wondered what speakers you are using. I am rather disappointed with my amplifier when connected to ML electrostatics. The high end is rolled off and the speakers sound like they are wrapped in heavy cloth a few times. Other amplifiers I have work well with the speakers and are rather impressive.
Old 9th November 2018, 12:05 AM   #6
Phloodpants is offline Phloodpants
There are a pair of 1000uF/16V filter caps for the high-voltage supply that often go bad in these amps. I don't have a specific recommendation for a replacement, but get something high-endurance, 105C, and 25V.
The 47uF input caps are pretty generic. Replace with some kind of fancy "audio grade" capacitor if you like.
http://hoppesbrain.com
Old 9th November 2018, 03:02 AM   #7
mbz is offline mbz  Australia
Service manual shows
4 x 24000uf/100V
2 x 4700uf/16V
4 x 1000uf/100V
No direct experiance with Adcom, it will come down in
part to available space/dimensions of the existing caps.
Should seriously consider a speaker protection circuit. maybe
a cheap chinese one if nothing else
Adcom GFA-5800 which capacitors?Hide this!Advertise here!
Measurements of an Adcom GFA-5800 mjarve Solid State 25 28th October 2018 04:00 PM
Adcom GFA-5800 DC offset off ErikLove Solid State 9 26th February 2013 06:18 AM
Adcom 5800 ROY'S Solid State 1 21st October 2012 10:37 PM
Adcom 5800 ROY'S Solid State 7 5th August 2012 05:18 PM
Adcom GFA-5800 question Peter Groth Solid State 9 29th June 2009 11:22 AM
