Hi guys! I need your precious support! I've to recap the amp in the picture below. The problem are the two big pink 8.000uF axial capacitors you can see on the amp board: it's impossible to find new axial capacitors in the market! So, I've decided to buy two radial (10.000 uF 35V) capacitors...but the problem is how to adapt them and how to fixed them on the circuit board Please, could you give me some advice?...I'm so confused! Thank you in advance for your patience and for your kindness!
Best regards!
Best regards!
What about them?
8200uF Vishay Aluminium Electrolytic Capacitors - Axial Leaded | Mouser Hungary
Sajti
Sajti
Thank you for your reply!
I'm searching for an higher uF value (10.000uF will be better) and in Europe I didn't find anything, for this reason I gave up and I decided to search for radial capacitors, trying to adapt them to the amp board...but I don't know how to do that.
Thank you!
Thank you!
This is from Mouser EU - they have 8 choices of 10,000uF in 25V/35V/50V variations. Doesn't seem too hard to find.
Aluminum Electrolytic Capacitors - Axial Leaded | Mouser
Wow!!!thank you for your precious help!
