Dual mono vs double bridged
Old 23rd October 2018, 10:07 PM   #1
neddy999 is offline neddy999  Ireland
Default Dual mono vs double bridged
Hi everyone,
I have a nad 3150 integated amplifier which sounds great to my ears and has sufficient power for my Kef LS50's. It has dual power supplies so in effect a dual mono amplifier (?!).
My question is, apart from headroom, would I get an increase in sound quality if I invested in a nad 2150 power amplifier and brigded both amplifiers. Empirically it would be suck it and see I guess, what about theoretically?
Thanks in advance
Nenad
Old 23rd October 2018, 10:10 PM   #2
Maybe I can add Kef ls50 nominal impedance is 8 phm though 4 ohm at 200 hz and minimum of 3.2 ohm, so nearer 4 ohm I guess.
Nenad
Old 23rd October 2018, 10:19 PM   #3
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
I bridged a couple of amps with very noisy power supply and poor PSRR and the noise largely cancelled.
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 24th October 2018, 01:14 PM   #4
Kay Pirinha is online now Kay Pirinha  Germany
Kay Pirinha's Avatar
Why did you start two different threads on exactly the same topic?
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 25th October 2018, 07:08 AM   #5
Ian Finch is offline Ian Finch  Australia
My question is, apart from headroom, would I get an increase in sound quality if I invested in a nad 2150 power amplifier and brigded both amplifiers. Empirically it would be suck it and see I guess, what about theoretically?....
Bridging is going in the wrong direction for low impedance loads. A minimum 3.5R for a nominal 8R speaker is quite normal now, as the defined minimum impedance reference point is generally ignored. More likely, modern speakers, even 8R rated types will use drivers with a compromise of 6R impedance, as do AV multi-box systems which are by far the most common box speaker products out there.
You may be hoping for an audible benefit to using less appropriate speaker impedances but I think that will remain something for your ears (and wallet to explore.
If only I had listened....
Dual mono vs double bridgedHide this!Advertise here!
Dual mono vs double bridged neddy999 Solid State 1 23rd October 2018 09:37 PM
2-channel regular ground, dual mono or "balanced"/bridged? Neutrality Headphone Systems 19 31st March 2013 01:54 AM
Grounding layout - Dual mono Bridged LM3875 GAH Audio Sector 1 15th September 2009 05:06 AM
Single or double transformers for dual mono amp? Bernie7 Class D 1 30th December 2008 02:19 PM
SI T-AMP mono bridged? SatChitAnanda Class D 5 13th July 2005 08:43 PM
Copyright ©1999-2019 diyAudio
