i can heard record playing in other inputs left right channels like cd tape tuner ?
That may be normal, the phono output would have to be shorted to ground to minimize
its crosstalk to the line input.
Don't play records while listening to tuner/CD.
Thanks Ray and PRR
Power is back on i think they are done already. I wont play amp till 100% sure they are finished around here
Not sure i heard the Phono while switching on my V8 and V8X amps. It might be normal with the V9, not sure, its phono section is much more powerful than the v8 and v8x
Maybe the 0.047uf cap i took out that was to ground in the signal path, as i had the CDE 2uf film cap in place of the old bi-polar - phono sounds great.
Funny thing is that the 1mv selctor only right channel increases in volume and left stays like the default 2.5mv selector
have to to just now address the hum via tone signal them across the inputs - right channel only, have to check input board again and maybe tone, no hum with straight dc
lol funny fan of docotor who also
phonostage schmatic pic
phono2 left and right continuity to earth x marks
photo above
caps removied C120/121
caps located in amp
cable used for phono van dammme cable copper spiral sheild /cotton and 2 signal wires
C117/18 wire used to film caps 26awg ptfe spc 2.0 uf film caps
