What Quad Colorado do I need: Quad 303 power amp
Old 9th October 2018, 09:59 PM   #1
XsamuraiX is offline XsamuraiX  United Kingdom
Default What Quad Colorado do I need: Quad 303 power amp
Just bought a Quad pre/power amp, the power amp (model 303) someone must have e use corrosive materials to clean the front of it and alot of the paint has come off, does anyone know what type of colour paint Quad used? I could repaint/respray it with it then.
Old 10th October 2018, 06:39 AM   #2
Ian Finch is offline Ian Finch  Australia
Seeing as that's the rear panel, it shouldn't be critical but you could remove the panel, prime and spray it with an auto retouching product that was close enough. I think the original may even be hammertone finish so matching the 1970s finish with a 2018 repair in a can from a store is going to be wishful thinking. Otherwise, Id blend a little fine copper into silver paint and adjust to correct colour for use with an air brush or retouching spraygun, if you have access to those.
If only I had listened....
Old 11th October 2018, 02:03 PM   #3
Hi Ian, I'll give that a go. As for the actual text on it, just a bit of paper with the words cut out and sprayed with white? I think I'll do it that way. From a resale point of view, if I did it all black would the value drop?
Old 11th October 2018, 02:21 PM   #4
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
I would suggest that from a resale point of view anything you do to it could lower it's value
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 11th October 2018, 05:17 PM   #5
I think the well-worn patch look is probably worse than having an unlabelled panel there. If you can match the finish closely from stock colours, I'd use dry transfer lettering like Letraset rather than paper labels, then carefully dust over (a dry application at some distance from the surface to avoid wetting and dissolving the transfers) with a clear lacquer and follow with a sealing coat. You can Google suppliers like Mayfair stationary and others in the UK if you need to view the font appearance.
As far as resale is concerned, you can't win with something that's already marred beyond simply touching-up or hiding the damage. A professional restoration would cost as much as a good condition 303 is really worth anyway and let's face it, the performance and sound quality of these is good but nothing to get excited about when compared to newer designs. For me, the value is in the aesthetic form. It's an iconic piece of clean, elegant design that should be on display somewhere.
What Quad Colorado do I need: Quad 303 power ampHide this!Advertise here!
(20) NSC/FSC MM74C00N DIP-14 Quad 2-Input NAND Gate . Quad Jimmy154 Swap Meet 0 4th May 2018 03:26 PM
RARE QUAD ESL57 ORIGINAL QUAD UK TREBLE PANELS - PAIR lampes Swap Meet 3 6th December 2012 10:02 PM
Early Quad II pre-amp, Quad 22 pre-amp and AM Tuner avant Swap Meet 3 3rd March 2012 03:34 PM
WTB: Any Quad II or Quad 22 units- working or not or parts for them hatrack71 Swap Meet 3 29th August 2010 03:46 PM
FS: Ei/Yugo KT90 quad, 6H30, svet KT88 quad - melbourne avian Swap Meet 9 15th April 2010 07:46 PM
Copyright ©1999-2019 diyAudio
