TL084CN upgrade on a Musical Fidelity Nu-Vista 300 power amp.
Old 12th October 2018, 07:08 PM   #21
zavan is offline zavan  Greece
I would like also to add to the "opamp equation" question, the factor of trimmer. The pcb of opamps is currently using a single turn 10% Bourns 3362 trimmer per opamp. (two) What about the replacement with the following trimmer.
Y4053200R000J0L Vishay Precision Group Foil Resistors | Mouser Greece
Old 12th October 2018, 09:58 PM   #22
Bigun is offline Bigun  Canada
Bigun's Avatar
You got bad case of upgrade-itis
Curious- Why are there thick ceramic spacers between the power devices and their heat sink on one side and not the other ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 12th October 2018, 11:00 PM   #23
Hehe nice one :-) The right side of the amp is the side which I have recapped. ELNA Silmics are surely bigger. I have also used an aluminum oxide ceramic insulator from AAVID. Better thermal performance, you never need to replace it mpla mplah for the precious Sanken SAP15. They are very expensive and hard to find. (at least the originals)
Also this upgrade gave me the opportunity, (since it's 2mm thicker) to put the whole channel pcb on rubber washers for reduced microphonics. Something that the discreet line amp pcb had already from "mama" MF.
And to finally answer your question: I haven't start the left channel yet.
4180G Aavid | Mouser Greece
Old 13th October 2018, 12:36 AM   #24
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
One thing to watch out for when replacing these opamps is oscillation. More modern opamps are generally faster and wider band, which is a good thing IF the circuit is designed for it.
Many people have replaced opamps with newer/faster ones and ended up with singing amps.
Doesn't always happen but you need to be aware and have some way of checking for it.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 13th October 2018, 12:48 AM   #25
Jan
YouTube
Old 13th October 2018, 01:20 AM   #26
Jan
I feel that MF has designed the pcb with the opamps exhaustively for this kind of cases that could cause such problems with opamps.
I surely don't know what will happen with a much newer op amp. But I know that other amplifiers, who people tried to upgrade opamps, didn't even have a trimmer for op amp offset voltage fine tuning.
So I am just curious to see the end result.
TL084CN upgrade on a Musical Fidelity Nu-Vista 300 power amp.Hide this!Advertise here!
Musical Fidelity Tri-Vista 21 DAC andy2 Swap Meet 1 4th January 2011 05:41 AM
Musical Fidelity Nu-Vista 300 circuit diagram pietjers Solid State 2 23rd September 2009 06:27 PM
Musical Fidelity X-A1 Upgrade ChrisR1983 Solid State 1 28th August 2009 11:16 AM
Upgrade the Musical Fidelity X-PRE ringo_the_hifi Parts 1 12th July 2009 05:25 PM
Musical fidelity Nu-Vista UltimateX86 Tubes / Valves 7 6th October 2004 04:41 PM
