Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Solid State Talk all about solid state amplification. |
Thread Tools |
#11 | ||
R.I.P.
A cohesive account of the phenomena is lacking. The dynamic impedance effects of loudspeakers has been covered by D.Self using waveforms with discontinuities. The question is : is FCD a genuine phenomena, or an alternative viewpoint of known existing phemomena. ![]() |
#12 |
#13 | |
USMPS http://groups.yahoo.com/group/switchmode/ |
#14 | |
Electrons are yellow and more is better!
Hm, all the experts are
![]() ![]() Quote:
/Per-Anders (my first name) or P-A as my friends call me |
#15 |
A-----------------
"Actually, I believe Graham was talking about the amplifier itself, possibly including loading effects. He simulated the transient response to a sine wave in SPICE, then did an FFT on the first cycle to determine the harmonic distortion of just the first cycle." I would want some assurance that what is being seen isn't just a computational artifact from SPICE. I have doneof SPICE transient analyses and specified that recording of data does not start until after 1ms and found that the FFT looks better sometimes. I've assumed it had a lot to do with the math and next to nothing to do with circuit performance under normal conditions. Of course, I may be wrong which is nothing new. B--------------------- "Music is comprised of transients. There is almost - exept when a tone is prolonged on purpose - no steady-state in music. Hit a string on a guitar and it will start swinging as soon as the plectrum or your finger lets go of the string. But the amplitude of the swinging wil not be constant, it will decrease untill it stops. Concluding; No steady state. As you may or may not see/know, the first swing from start point to start point is the one with the biggest amplitude, as it will fade gradually as already sayd. Here comes the question: What can cause for a signal to be dampened in it first swing - or cycle (as Graham appropiately calls it)?" This seems to imply that aqmplifier performance during the current cycle is dependant on it's state during the immediately preceeding cycle. "First cycle distortion" would just be a special case of this proposition. If you assume, for the sake of argument' that the slew rate is adequate for the peak voltages implied by the rails, then it seems to me you are arguing for some form of semi-conductor memory. I'm not familiar enough with the relavent literature to know whether this has been investigated or not, but it seems to me this is what the proposition comes down to if you eliminate inadequate slew rate as a mechanism. |
#16 |
You cannot get accurate spectral analysis results with an FFT of one cycle....That is a horrible window.
Best you can do is record it, and duplicate it in time, making it a pseudo sine wave. Or, record it, and apply nulling techniques with sine waveforms. John
I hate all these smart gadgets..I refuse to buy things that are smarter than me. I've made a list of those things... Cabbage just made the list. |
#17 | |
diyAudio Moderator Emeritus
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is." |
#18 | |
#19 | |
Banned
Actually it's intimately related to the transient response of the circuit. What you're seeing is the need to wait until the transient response settles out until the signal you're doing the FFT of becomes truly periodic. You can show analytically (using Laplace transforms) that for a first order low-pass filter, the response to a pulsed sine wave is an undistorted pulsed sine wave with shifted phase, plus a decaying exponential. Since the FFT of a single cycle is just the spectrum of the periodic extension of that single cycle (provided the sample interval is chosen right), the spectrum is that of the periodic extension of the sum of two signals: 1) The undistorted pulsed, phase shifted sine 2) The periodic extension of the decaying exponential (from the transient response) This is for a single pole low-pass filter only. The presence of (2) above causes the distortion to appear, since the periodic extension of a decaying exponential looks like a high-pass filtered square wave with every other half-cycle negated. It can be shown analytically that the amplitude of the component (2) above goes to zero when the phase shift of the sine goes to zero. Thus the "first cycle distortion" of the output goes to zero as the bandwidth goes to infinity. |
#20 |
So how about the transient response of the digital filter of the CD player, for example? It has rise time (10% - 90%) no shorter than 17us and limited initial dv/dt, far below slew rate of the contemporary amplifiers. And how about analysis of the transients of the musical instruments itself?
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Graham's Class A/JLH output | jcx | Solid State | 135 | 24th May 2008 07:12 AM |
50/60/whatever cycle hum | engels | Tubes / Valves | 11 | 2nd January 2008 03:48 PM |
Graham Maynard | Stocker | Everything Else | 0 | 28th March 2007 04:47 PM |
Remember First cycle distortion? Read all about it . . . | boholm | Solid State | 0 | 27th June 2004 07:28 PM |
New To Site? | Need Help? |
