Hafler SE120 power supply capacitors
Old 16th September 2018, 02:55 PM   #1
ivandrocco is offline ivandrocco  United States
Default Hafler SE120 power supply capacitors
Id like to refresh my SE120 by replacing the power supply capacitors, rectifier bridge, and adding an inrush limiter.
I believe the stock DH120 has 6600uF 60V capacitors, and the common upgrade is 22000uF 63V. Should I look to do the same on the SE120?
Mouser has some Kemet 33000uF 63V caps for $19 a piece. Theyre cheaper than the 22000s.
Old 17th September 2018, 09:42 PM   #2
Did some reading on capacitor selection and it seems like these are a nice combination of low ESR, high ripple, and price. Maybe overkill on capacitance but that seems like it shouldn't be a problem with an inrush limiter... was planning on 1 ohm 20 amp, as well as the 25 amp rectifier bridge.
https://www.mouser.com/ProductDetail...2D630N393MC92M
Anything else I should consider replacing while I'm in there?
http://hafler.com/pdf/archive/SE120_amp_man.pdf
Hafler SE120 power supply capacitorsHide this!Advertise here!
Hafler Transnova 9300: DC offset & power supply puzzle Mayank Solid State 24 7th June 2018 02:03 PM
WTB hafler dh120 se120 p125 9130 or similar ivandrocco Swap Meet 0 24th July 2017 03:53 PM
Need advice on capacitors for power supply bypass (Hafler P-500) Aaron D Solid State 8 13th February 2017 12:30 AM
Capacitors for power supply Jrp27 Power Supplies 11 20th May 2016 05:59 PM
hafler dh120 power supply upgrade phillyboy55 Solid State 1 2nd April 2011 01:49 PM
