Looking for a little power amp project (spoilt for choice on here)
Old 19th September 2018, 11:43 AM   #31
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
The USSA-5 is a highly regarded amp and on my to-build list. I have all the parts in fact, but I am not sure it’s appropriate project for the OP who said this is his first step up from a TPA3116 class D amp. I would say it’s an amp for a seasoned builder with at least a couple of discrete Class A or AB amps under his/her belt. The power supply is much more than SMPS brick and a cap Mx, then there are the parts costs (the actives alone run circa $175 IIRC), and there is setup adjustment to zero offset and set bias. This is where the Alpha is a bit better. Same PSU and chassis requirement but inexpensive easy to find actives and no setup adjustments.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 19th September 2018, 11:51 AM   #32
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Originally Posted by Hikari1 View Post
Your desires for small chassis and class a mean low wattage and low bias. Class a is all about bias and heat dissapation. Go with a bigger chassis.
Or with class AB amp that operates in class A most of the time. This saves a lot of the heat/size issue. The Honey Badger is great.
[ audioroot.net | hifibau.ch ]
Old 19th September 2018, 12:37 PM   #33
Puggie is offline Puggie  United Kingdom
To be fair, I'm new to scratch building amps, but I do build satellites from build manuals and spent 7 years teching in a studio repairing quad 405s, studer tape machines and endlessly recapping a large neve mixing desk. So I'm not a noob from the build/assembly point of view, just new to the plethora of amp designs available. Neither am I particularly knowledgeable about amp design which is why I want to start with a simple class a, half the point of this is to get a better understanding of discrete electronics, the nice amp at the end is a well engineered byproduct!
I've dug out a heatsink, 350mm long 95mm tall (once I've faced the cut edge off) with 50mm long combined fins and base. I hope to cut this into two to make a stereo (ACA) amp.
Old 19th September 2018, 01:13 PM   #34
e_fortier is offline e_fortier  Canada
e_fortier's Avatar
Originally Posted by acg View Post
USSA-5 is circa 25w Class A. Not sure if it would fit in your chassis though...it might. There is a GB on here for the amp and for the power supplies.
+1
Also, help from Fab if you have any questions along the way is simply amazing!
Looking for a little power amp project (spoilt for choice on here)Hide this!Advertise here!
Choice of a bookshelf project greypey Full Range 26 21st December 2013 12:37 PM
Choice of power amp project Simtu Solid State 2 20th March 2012 05:53 PM
HELP PLEASE! Choice of first power amp project. brianco Solid State 17 20th December 2006 05:40 PM
Project choice for KT88 JDeV Tubes / Valves 6 16th August 2005 07:27 PM
Best tube choice for 1st SET project? roundel325 Tubes / Valves 2 1st April 2004 04:29 AM
