Lateral Mosfets Double Die TO-3 ESP P101
Old 17th September 2018, 05:11 PM   #21
a1095us is offline a1095us  United States
Default Double Die
Originally Posted by Ian Finch View Post
As I understand, the OP wants to use TO3 parts because the chassis already has provision for mounting them. That makes sense, rather than hacking the heatsink about, unless absolutely necessary.
The problem is that whilst Lateral mosfets are a sure-fire and simply applied device, the metal can varieties are close to un-obtanium presently. There was yet another thread here only week or so ago, moaning about general scarcity of lateral mosfets - check the recent threads if interested in the suggestions but I don't think you'll find much stock of genuine TO3 parts presently, let alone the double-die varieties.
From the current Profusion site. Ordering shortly!
Old 17th September 2018, 05:42 PM   #22
ctrlx is offline ctrlx  United Kingdom
Originally Posted by ivanlukic View Post
Rod's boards are for two pairs of TO3P latfets (flatpack plastic types), not for TO3! Here is the pic of my ESP P101 build.
ivan, can you tell me what is the clipping performance at 10KHz for this amp?
Old 17th September 2018, 06:12 PM   #23
ivanlukic is offline ivanlukic  Serbia
Keep in mind that in their application note Hitachi explicitly suggests that Laterals should be directly soldered to the PCB and to keep connection between output transistors and PCB as short as possible to prevent oscillation. What Tandberg did was not ideal and could be the source of troubles. I think that malfunction could have been caused by that unfortunate detail.
The world has enough for every man's need, but not enough for every man's greed. Gandhi
Old 17th September 2018, 06:21 PM   #24
I never tested it at clipping power because unfortunately I don't have that powerful 8 Ohm dummy load. I tested it at 4 Ohm dummy at lower powers and noticed some strange oscillation bursts but my build was with 68nF bypass caps instead of 100nF. When I desoldered 68nF and put 100nF that bursts disappeared. I think that 220nF would be even better. I built it in 2012 and used original Hitachi Latfets.
I must say that I always like the sound of amplifiers with one pair of outputs more than same amplifier with two or more output pairs. For P101 I used two pairs because I had a stock of Hitachi latfets but I think that it would be better if I used only one pair. I only build home amplifiers, never sound reinforcement amplifiers.
Old 17th September 2018, 06:24 PM   #25
If you would read the posts carefully, you would see that I stated the amplifier section never failed in all the many years I used the Tandberg. The multi-wafer selector switch and other controls were the demise of the 3012 amp.
If you keep the wiring short, you should not have an issue.
I have built a few this way without problems. Bias adjusts fine and looks good on a scope. I think you are over-reacting a bit!
Old 18th September 2018, 09:34 AM   #26
I never tested it at clipping power because unfortunately I don't have that powerful 8 Ohm dummy load..
you can test with no load, BRIEFLY! (the zobel R will disspate about 0.3W assuming 10R/0.1uF at 40Vpeak/10KHz sine.)
Old 18th September 2018, 02:48 PM   #27
Kris0603 is offline Kris0603  Sweden
I love the Exicon laterals of my Fetzilla, was thinking, could a P-channel lateral serve in something like the SissySIT?
Old 19th September 2018, 08:35 AM   #28
I used 4R dummy load at 10kHz. Here is the scope result. Not exactly what I expected. I expected nice flat line at the clipping.
Old 19th September 2018, 03:52 PM   #29
Ian Finch is offline Ian Finch  Australia
That could be due to the measurement method but the preceding circuitry could be rounding off the leading edges too.
If only I had listened....
Old 13th March 2019, 12:20 AM   #30
Default Tandberg P101 Progress
ESP P101 amp built from Tandberg 3012 transformer and heat sink assembly.
Barely Luke warm with 30mA bias. Sound is exceptionally clean.
Power light with standby and on condition. Light for speaker relay status.
Need to clean up the wiring a bit. More to come.
More to come
Lateral Mosfets Double Die TO-3 ESP P101Hide this!Advertise here!
Lateral MOSFETs JaredC79 Solid State 79 1st March 2016 09:39 AM
WTB: Lateral MOSFETS for ESP P101 Amplifier hongrn Swap Meet 2 25th April 2014 03:43 AM
double die lateral fet vandenberg Swap Meet 2 20th November 2013 02:28 PM
Double-die mosfets in P101? Daniel(Del) Solid State 7 16th November 2008 10:07 AM
P101 Problem. Bad MOSFETs??? vinyvamos Solid State 4 13th January 2008 01:46 PM
Copyright ©1999-2019 diyAudio
