Marantz PM17 Repair
Check the voltages at the emitters of Q711 and Q712, referenced to ground. You should see about 1.2v there. If not, it is likely Q702 has died - though you can also then check R729/R730 are OK
Actually, were drivers Q713 and Q714 damaged ? If they were damaged, check Q711/Q712 and all of the connecting resistors.
. Q713, Q702 and Q714 were not damaged, but just in case for the tests I'm using the good channel transistors. Tomorrow I will check the voltages at the emitters Q711 and Q712.
An observation: when I turn on only the good channel, the source selection LED works, when I turn on only the bad channel, the source selection LED does not work. Thank you for your patience
These are the readings I've done:
Service Manual Readings
-Q712, Q711----------1.2V---------------0,90V (emisor)
-Q713, Q714----------0.65V------------- 0,394V (emisor)
-Q715, Q716----------42,6v--------------38,56V (colector)
-Q715, Q716--------0,026-0,036V--------0,005-0,006V (emitter)
The readings are low, are we doing well?
Hello, the bad channel worked, no bulb and audio signal !!!, but I received the transistors 2SC3519 / 2SA1386 and now the good channel does not work because it has the old small transistors of the channel that exploded. So I have to replace: "SC3419-2SC4793 / 2SA1837" and the work will be finished.
I have read about replacements for these transistors but I am very confused. What can be good replacements for ?:
-2SC3419 and
-2SC3519 / 2SA1386
Thank you very much.
Hi, I'm sad and tired, I bought Profusion 2SC3519 / 2SA1386 and everything was perfect. I tried my luck in a Spanish store with SC3419-2SC4793 / 2SA1837 but when I went up the bias or a bit the volume with audio ... boom the bulb turned on and there was a short circuit. I have verified with certainty that they are bad or they are false.
Please, what replacements are for ?:
- 2SC3419-Y (It has to be only with the letter Y)
Characteristics of the 2SC3419-Y bipolar transistor
Type - n-p-n
Collector-Emitter Voltage: 40 V
Collector-Base Voltage: 40 V
Emitter-Base Voltage: 5 V
Collector Current: 0.8 A
Collector Dissipation - 5 W
DC Current Gain (hfe) - 120 to 240
Transition Frequency - 100 MHz
Operating and Storage Junction Temperature Range -55 to +150 ° C
Package - TO-126F
2SC4793 / 2SA1837 (It can be Y or it can be O) Bipolar Transistor
Characteristics of the 2SC4793 bipolar transistor
Type - n-p-n
Collector-Emitter Voltage: 230 V
Collector-Base Voltage: 230 V
Collector Current: 1 A
Collector Dissipation - 20 W
DC Current Gain (hfe) - 100 to 320
Transition Frequency - 70 MHz
Package - TO-220F.
Thank you very much. Now I will not bother you anymore.
Type - n-p-n
Package - TO-126F
Type - n-p-n
Package - TO-220F.
Thank you very much. Now I will not bother anymore.
I had not seen that in Profusion they have replacement for SC3419 and 2SC4793 / 2SA1837. Today I made the order:
2SC4793LB-TF3T - Power Transistor 230V 1A
2SA1837LB-TF3T - Power Transistor -230V -1A
BD139-16 - Power Transistor 80V 1.5A
The brand is UTC (Unisonic), hopefully luck
Hi, the Profusion transistors have arrived. I have tried with the bulb and I have adjusted the Offset and the Bias and after I have put audio signal at low volume, everything is perfect !!!!. But now the real test comes, plug without the bulb. Any suggestions before doing this ?, Thanks.
A week working properly !!!!!:):):):):)
In case it serves someone with a Marantz PM17 these are good replacement transistors:
2SC3284/2SA1303(sanken)------2SC3519/2SA1386 (sanken)
2SC4793/2SA1837 (toshiba)-----2SC4793LB-TF3T /2SA1837LB-TF3T (Unisonic)
2SC3419Y-------------------------BD139-16 (Unisonic).
Profusion/UK
Thanks to everyone and to this forum for the help.
