My attempts at a design of a 3 stage amplifier
Old 13th August 2018, 06:41 PM   #41
Mooly's Avatar
Simulating power supplies can be done a couple of ways. One method is to set each rail up as a voltage source that appears like ripple. The three images show the settings for a - and + 45 rail of fixed ripple. This can be useful for evaluating power supply rejection.
A second method is to add an AC voltage source and bridge rectifier to the simulation. Here I have used just 1000uF reservoir caps to highlight the ripple.
Old 13th August 2018, 06:45 PM   #42
Mooly's Avatar
One thing to note, the ripple simulation is now exclusively a 'transient' type meaning that DC analysis (the .op command) does not work. This is because there is no fixed DC rails powering the circuit, they are derived just like the real thing from an AC source.
If you right click the two voltage sources feeding the bridge you will see how they are set up. Note the 180 degree phase shift for one of them. Here is the sim file. If you are using LTXVII then the 30 amp rectifiers may not be included in the model library... just pick something else that is.
Old 13th August 2018, 10:04 PM   #43
edbarx is offline edbarx  Malta
In KiCad I used PWR_FLAG and the error did not appear anymore. However, there is still one remaining problem before I can proceed to successfully process my schematic. KiCad is telling me transistor footprints like To-92, To-225, To-3PL, etc are legacy and that I must enter their modern equivalents manually. I tried good-old-google, but it seems, at google they are more interested in giving links to commercial sites rather then giving me a link to a site that can help me.
Does anyone know of a list listing these legacy footprints and their modern codes?
Old 19th August 2018, 04:50 PM   #44
I am reading tutorials about using LTSpice, and in fact succeeded to produce charts for a simple circuit diagram, but I am still stuck to produce meaningful output from ltspice. The reason is I cannot make heads or tails of how nodes of a circuit are represented in the list of variables displayed whenever I try to draw a new chart.
What is the meaning of these?
V(p001)
V(n001)
V(n002)
V(n003)
I assume the meaning of Ie(Qn), Ic(Qn), Ib(Qn) are for the emitter, collector and base currents of Qn respectively.
How are nodes numbered? Is there a way of avoiding this ambiguity?
Old 19th August 2018, 05:12 PM   #45
EssB is offline EssB  United Kingdom
Nodes are numbered automaticaly by LTSpice when you make connections on your schematic. If you hover the mouse over a connection you can see the node number in bottom left of window.
You can label nodes with meaningful names if you want: put mouse over connection -> Right click -> label net.
If you want to plot the voltage at node n007, you just select V(n007) from the list in the plot dialog.
Old 20th August 2018, 11:40 AM   #46
I am using LTspice to simulate a simple amplifier which I am designing for learning purposes. Feedback and suggestions are welcome and appreciated.
These are the screenshots from LTSpice.
Old 20th August 2018, 04:05 PM   #47
These are my results after increasing key resistors for the circuit to use +/- 60V DC. The simulation amplifier has been added an output stage that drives directly from the VAS. I know driving a large output stage directly from the VAS is rather naive, but there is nothing wrong in simulating an amplifier like that if it helps undestanding of key concepts.
The blue and red plots are currents from the power supplies. The blue plot is the output voltage developed across the output load resistance of 25 Ohms. The simulation frequency is 4500Hz. The thing that is exciting me is the 'nice' looking sine wave, which suggests distortion should be low, but how do I tell LTspice analyse for distortion?
The next step will adding more workhorses in the output to drive a proper 8 Ohm load and a driver stage.
Old 20th August 2018, 06:16 PM   #48
Mooly's Avatar
Have a read at posts 19 and 20 here:
Installing and using LTspice IV (now including LTXVII). From beginner to advanced.
Old 20th August 2018, 06:25 PM   #49
Originally Posted by Mooly View Post
Mooly,
Thanks for that link, I was looking for that thread of yours the other day and couln't find it - don't know why, probably my rubbish eyesight.
Old 20th August 2018, 06:29 PM   #50
Mooly's Avatar
Lol its also a clicky on my signature line.
My attempts at a design of a 3 stage amplifierHide this!Advertise here!
Phono stage design considerations part 1: choosing 1st stage tube Joshua_G Tubes / Valves 215 26th August 2018 06:30 PM
Amplifier design: how to connect a stage with the next one? Bricolo Solid State 11 10th August 2018 08:34 AM
Pre-amplifier circuit not working despite attempts to fix it Rudi1441 Analog Line Level 5 18th July 2016 03:35 PM
LF Line Level Stage design to preceed class D amplifier undefinedza Analog Line Level 13 18th September 2014 09:26 AM
how to design mosfet amplifier stage? pzung Solid State 2 22nd January 2010 07:58 PM
Copyright ©1999-2019 diyAudio
