My attempts at a design of a 3 stage amplifier
Old 16th January 2019, 07:33 PM   #321
edbarx is offline edbarx  Malta
Default Negative voltages?
I am analysing the attached circuit to determine the sign of the voltage at the input, and at the large feedback capacitor terminal that is not connected to ground. LTSpice is telling me the small voltages are NEGATIVE with respect to ground. This means, the large capacitor should be soldered with its cathode to the resistor and the anode to ground. The input capacitor should be connected with its cathode to the base of the input transistor.
Am I right?
Old 16th January 2019, 07:46 PM   #322
R Dijk is offline R Dijk  Norway
c3 and c4 bipolar.
Old 16th January 2019, 08:03 PM   #323
Mooly's Avatar
That scenario is pretty normal. I would advise actually measuring the voltage across the real caps and rotate them accordingly to suit the actual polarity.
Old 19th January 2019, 04:35 PM   #324
Three more transistors to complete the circuit. Tomorrow, hopefully, I should be able to finish interconnecting the input, VAS, VBE multiplier and overcurrent limiter PCB with the main PCB which hosts the output stage and smoothing capacitors.
After that, it will be time to do testing with audio signals.
Old 19th January 2019, 06:24 PM   #325
Mooly's Avatar
An then the fun starts
Old 22nd January 2019, 03:08 PM   #326
The remaining parts arrived. I will try not to let excitement direct me. Being the last phase before trying the amplifier with an audio signal, this phase is critical and errors would only mean blown parts that take weeks to arrive by post.
I will try to be cautious and very patient.
When I power the complete amplifier circuit with a feeble power supply, I will test various critical points to verify the DC voltages are as they should.
Old 22nd January 2019, 03:20 PM   #327
Mooly's Avatar
Slow and steady is the way to go. Good luck
My attempts at a design of a 3 stage amplifierHide this!Advertise here!
Phono stage design considerations part 1: choosing 1st stage tube Joshua_G Tubes / Valves 215 26th August 2018 06:30 PM
Amplifier design: how to connect a stage with the next one? Bricolo Solid State 11 10th August 2018 08:34 AM
Pre-amplifier circuit not working despite attempts to fix it Rudi1441 Analog Line Level 5 18th July 2016 03:35 PM
LF Line Level Stage design to preceed class D amplifier undefinedza Analog Line Level 13 18th September 2014 09:26 AM
how to design mosfet amplifier stage? pzung Solid State 2 22nd January 2010 07:58 PM
Copyright ©1999-2019 diyAudio
