My attempts at a design of a 3 stage amplifier
Old 3rd November 2018, 08:51 PM   #291
edbarx is online now edbarx  Malta
Silence does not mean I abandoned the project. It only means a steeper uphill path is slowing the project's progress.
Old 6th November 2018, 09:29 AM   #292
Some Questions:
a) Is a simple pre-driver amplifier circuit possible to have a very low distortion and high stability? [ distortion < 0.01%; thermal quiescent current stability, no self oscillations at all output levels ]
b) I suspect my never-ending quest to devise a pre-driver circuit with the above characteristics, and yet having a very low component count, is an impossible feat. Am I right?
c) Is it possible to use a very simple circuit to drive the drivers of a large power amplifier?
I tried the above until I couldn't stand more my aching tired head.
If I am running after the wind, please, reply explaining why, but please do it civilly.
Old 6th November 2018, 03:18 PM   #293
Mooly's Avatar
I thought you were happy enough to build a prototype of your design a few days ago but then you keep moving the design goals.
High power high voltage amps are never straightforward and I know you were trying to make your design retain an existing output stage configuration which again is another limiting factor.
Sometimes you can be better to start again with a clean sheet and explore different topologies (and their problems ) and hopefully their solutions.
Success always stands on the shoulders of failure (unfortunately).
Old 6th November 2018, 03:49 PM   #294
That means expecting a very simple pre-driver circuit is contrary to amplifier design experience.
I saved all circuits: those that performed well in LTSpice are saved. I can refer to those.
I am modifying the original amplifier circuits so that the output transistors are isolated from ground. This will allow me to use the common grounding scheme that uses the 0V rail as ground.
Old 6th November 2018, 07:02 PM   #295
The MJE15033 and MJE15032 are rated at Ic_max=8A and Vce_max=250V. A maximum current of 8A means the die area is too big to be used for a VAS as the parasitic collector-base capacitance is dependent on the area of the die. While I will keep the best performing circuit unchanged I will use the 2S3600 and 2SA1406 which are rated at Vce_max=200V and Ic_max=100mA. This is a reduction of current handling by a factor of 80 times. With this change I expect the VAS's parasitics should be greatly reduced.
Old Yesterday, 12:28 PM   #296
I am about to move the output Inductor-Resistor filter from the 0V rail to the hot output terminal where it is usually found. This will need a small separate PCB which will be bolted to the main PCB. I will keep the connecting wires the shortest possible.
In the original circuit a series Resistor-Capacitor filter was placed after the Inductor-Resistor filter. Since readers of this thread including Mooly, the moderator, insisted the Inductor-Resistor filter should be connected AFTER the Resistor-Capacitor filter, I would like a last comment before I make the actual physical circuit changes. This is not modifying a schematic to be simulated by LTSpice or equivalent, but the actual circuit.
I am attaching the .asc schematic. Is this where the mentioned filters are usually connected?
Old Yesterday, 02:51 PM   #297
Mooly's Avatar
Yes
My attempts at a design of a 3 stage amplifierHide this!Advertise here!
Phono stage design considerations part 1: choosing 1st stage tube Joshua_G Tubes / Valves 215 26th August 2018 06:30 PM
Amplifier design: how to connect a stage with the next one? Bricolo Solid State 11 10th August 2018 08:34 AM
Pre-amplifier circuit not working despite attempts to fix it Rudi1441 Analog Line Level 5 18th July 2016 03:35 PM
LF Line Level Stage design to preceed class D amplifier undefinedza Analog Line Level 13 18th September 2014 09:26 AM
how to design mosfet amplifier stage? pzung Solid State 2 22nd January 2010 07:58 PM
