Pioneer Amps
Pioneer Amps
Old 13th June 2018, 04:53 PM   #1
xXBrunoXx is offline xXBrunoXx
Question Pioneer Amps
Hello, Do Pioneer amps like to run hot ?.
I own a Pioneer A-702r amplifier , and the heatsinks are HOT even at low power , the drivers are on a small U heatsink and you can't touch them how hot they get. Room temperature is 25 degrees.
I measured the quissance current based by the service manual , and its exactly as recommended in the manual.
Also , one more question. I get 20mv where it says , power rails are +- 55vdc . how do I calculate quiss current by these, or I can't ?
Old 13th June 2018, 05:42 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
16mV across 0.44R is not a lot. About 9mA so should run cool. Not as if it is class A.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Pioneer AmpsHide this!Advertise here!
Pioneer SM83 PP amps jevta Tubes / Valves 3 25th September 2008 11:46 PM
80's Pioneer Amps highboy_coupe Car Audio 2 20th July 2007 12:54 AM
Summing (I/V) op-amps for Pioneer DV-59i hollowman Digital Source 2 12th March 2007 04:46 PM
pioneer sa9500II AMPS djmaiden Everything Else 24 26th November 2005 02:53 AM
Copyright ©1999-2019 diyAudio
