USSA-5 Build with Review
Old 13th August 2018, 06:09 PM   #201
tonza75 is offline tonza75  Europe
Do
Old 13th August 2018, 06:26 PM   #202
ggetzoff is offline ggetzoff  United States
ggetzoff's Avatar
Originally Posted by pinnocchio View Post
Enjoying music in mine! Hehe
Delightful !
Ciao!
Do
Do,
Me too!
Greg
Airline Pilot-If it's not Boeing I'm not going.
Aleph J, DCB1, VHEX + USSA-5, BA-3 Pre, DCG3, USSPA, Transcendent Sound Masterpiece
Old 15th August 2018, 07:20 PM   #203
sledwards12375 is offline sledwards12375  United States
Hello All:
I am up to section 8.17.1 , Adjust output MOSFET current close to intended final bias.
Everything has measured fine up to this step. When I apply power, TP4/V- and TP2/V+ read 0.00 volts, and the offset at output is about 0.5 volts. The MOSFETS are not getting warm. I get the same readings on both boards, so I believe parts are installed correctly.
Should I proceed to increase/decrease P1/P2 to turn on MOSFETS?
Steve
Old 15th August 2018, 07:43 PM   #204
fab is offline fab  Canada
fab's Avatar
Hi
If all previous steps measured fine then it is normal to get 0 volts before adjustments if the vgs off of the mosfet are on the high side (red color band for example). Therefore you can proceed to adjust P1/P2 to get output bias while keeping DC offset close to 0 (<50mv until final bias). At final bias you can tweak dc offset to < 5mv once température is stabilized.
Fab
Old 15th August 2018, 07:56 PM   #205
Thanks Fab. Will post VGS calcs for confirmation soon.
Old 15th August 2018, 08:07 PM   #206
Project16 is offline Project16  France
Project16's Avatar
For information on the black pcb I added TP1 => V+ and TP3 => V-.
Old 15th August 2018, 09:39 PM   #207
fab/Project16:
I have attached my VGS calculations for review. These are fillable PDF forms and may be used by those interested to post their results.
Steve
Old 15th August 2018, 10:43 PM   #208
Apparently forms behave differently on iPhone and iMac version of Acrobat. Here are jpg images of my results.
Old 16th August 2018, 03:36 AM   #209
fab's Avatar
You got 100% for your test
Fab
Old 16th August 2018, 04:13 PM   #210
fab's Avatar
Hi
You have clean assembly, proper positioning and good size heatsink. Your input cap is a little (far) more expensive than the one specified in the BOM...
Fab
USSA-5 Build with ReviewHide this!Advertise here!
Odd Watt Audio Alpha Build and initial review cgnman59 Tubes / Valves 6 26th April 2017 04:12 AM
SMPS vs LINEAR PS: Let's build up a serious technical review-list Centvrion Power Supplies 18 7th March 2011 05:09 AM
Honest opinion (peer review) about this 4Way before I build it Yoshy Multi-Way 54 16th December 2010 07:37 AM
Copyright ©1999-2019 diyAudio
