USSA-5 Build with Review
Old 23rd May 2020, 10:18 PM   #1321
Vunce is online now Vunce  United States
Originally Posted by Bfpca View Post
...... The fans I have in it sound like a small helicopter is in the amplifier. Not nice in my quiet listening room.
Old 24th May 2020, 07:54 AM   #1322
Harry3 is offline Harry3  Australia
Originally Posted by pinnocchio View Post
Thanks all for the comments!
For me it was well worth it just for the extra 2.2V on the PSU. I will give it a listen during the week.
Ciao!
Do
Hi Do
any comments on how the LT4320 sounds in your system?
Old 24th May 2020, 08:43 AM   #1323
AnthonyA is offline AnthonyA
Originally Posted by Vunce View Post
Ho... Just install a speed potentio.. It don't really need fast speed something push the air is good enough
Old 24th May 2020, 09:10 AM   #1324
or a 10Volt 5W zener in series with a 12V fan. However some fans might not start up if they don't get 12V on start up.
Old 24th May 2020, 09:23 AM   #1325
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
I have a pair of SLB that I will use in a future amplifier. My USSA 5 is using a CRC PSU and it is totally silent, even with my ear directly on the tweeter, you would believe the amplifier is turned off. I wanted to use the SLB for the USSA 5 but with 4V drop, I would need to change my transformers, which will never happen because I bought those very nice encapsulated Toroidy transfos and I just love them. But I'm planning to replace the diode bridge with the LT4320. They're already assembled and tested, just need time to migrate them over.
Do
I am in the stage of thinking about the PSU of my USSA-5 build. I have already ordered the SLB boards. Now I need to figure out the transformer:
  • Is +/- 24 DC rail voltage okay for the USSA-5? I am thinking of cranking the bias current up to 1.5A to 2A or so, depending on how hot the heatsinks get (I am happily running my Alephs at 1.9 A / 24 V rails in the same chassis).
  • What AC voltage rating for the transformer secondaries would be right for 24 V rails with the SLB? I would guess that a Toroidy with 21 VAC would be about right, but it would be nice if someone could confirm / comment on this.
Scan waveguides (elliptical / circular) MATAA audio analyser Open Source Monkey Coffin
Old 24th May 2020, 09:42 AM   #1326
I'm sure Fab will respond about voltage level requirements.
In the mean time look at post 880 page 88.
PS 4 ohm or 8 ohm?
Old 24th May 2020, 10:38 AM   #1327
meanie is offline meanie  Singapore
I got +/- 25.9Vdc on my SLB with a 600W, 22+22Vac trafo, drawing about 3.2A resistor load under test. SG main voltage is abit high at 235Vac.
So i think if you can get 21Vac trafo, it may be perfect.
Old 24th May 2020, 12:25 PM   #1328
manniraj is online now manniraj  India
19+19Vac and 5A each secondary I get around +/-25vdc without load using the LT4320 of Prasi CRC psu boards.
Old 25th May 2020, 01:20 AM   #1329
fab is offline fab  Canada
fab's Avatar
For the PSU, the LT4320 gives about more than 2 Vdc more than standard diode bridge. I have not used the SLB but I believe that the voltage drop can be adjusted and reduced for less load current. In any case if it is about 2 or 2.5Vdc or so it is mostly compensated by the increase of the LT4320...
So in the end, chose your voltage transfo the same way as if it was a normal PSU. One volt difference is marginal. But as Harry3 indicates read post 880 regarding 4 or 8 speakers.
Fab
My stuff USSA, FSSA, USSPA: https://fabaudio.online
Old 25th May 2020, 05:59 AM   #1330
If slb is same as cap multiplier..
Slightly higher ac voltage is fine.. Just turn the potentio to drop
More headroom
Also from what I tried... The diode quality becomes not so important.
Don't worry bout it few volts is just few volts
USSA-5 Build with ReviewHide this!Advertise here!
Odd Watt Audio Alpha Build and initial review cgnman59 Tubes / Valves 8 24th February 2020 03:09 PM
SMPS vs LINEAR PS: Let's build up a serious technical review-list Centvrion Power Supplies 18 7th March 2011 04:09 AM
Honest opinion (peer review) about this 4Way before I build it Yoshy Multi-Way 54 16th December 2010 06:37 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
