USSA-5 Build with Review
Old Today, 11:39 AM   #1031
nikosokey is offline nikosokey  Greece
nikosokey's Avatar
Originally Posted by meanie View Post
Thanks, Fab!
Something happened when I was trying to increase bias, my meter show the reading jumping back and forth between 65mA and 58mA.
Then I realized I had a bad quality pot (P1,P2), so I had to strip the amp again and replace the pots.
Pls use quality brands like Bourne, you will get fewer issues in the long run.
Hi Meanie
i have the same issue.... cold welding bad join on trimmer Vishay ...solved..
T93YA102KT20 Vishay / Sfernice | Mouser Greece
my measurements were slowly coming to me...
Titan 2000 ,Cressendo Millenium 2000, P3A ,VSSA ΤΟ3 ,B1 Buffer ,Golmund Mimesis 9.2 Clone ,Preamplifier Dispre 2 - JFET, DCB1 SALAS, D-Reflector, BibFet, Buffalo II,ES9018K2M, Arduino LDR Volume, AK4490 Discrete Mirand Audio,SSHV2, 6V6 Salas Preamp.
Old Today, 11:48 AM   #1032
meanie is offline meanie  Singapore
Originally Posted by nikosokey View Post
Hi Meanie
i have the same issue.... cold welding bad join ...solved..
I will recheck while changing the pots.
It was working fine @1.3A till this attempt to increase bias...
Marantz 7 clone - BA3FE - Yarra/Melbourne Preamp - USSPA - Korg Nutube - BabyHuey EL34s - 2ACAs - F6 - M2XSLB - 2Whammy -
USSA5SLB
USSA-5 Build with ReviewHide this!Advertise here!
Odd Watt Audio Alpha Build and initial review cgnman59 Tubes / Valves 6 26th April 2017 04:12 AM
SMPS vs LINEAR PS: Let's build up a serious technical review-list Centvrion Power Supplies 18 7th March 2011 05:09 AM
Honest opinion (peer review) about this 4Way before I build it Yoshy Multi-Way 54 16th December 2010 07:37 AM
Copyright ©1999-2019 diyAudio
