Fixing Mark Levinson 300 series start issues
Fixing Mark Levinson 300 series start issues Please consider donating to help us continue to serve you.
Old 1st April 2018, 01:43 PM   #1
willcycle is offline willcycle  United States
Default Fixing Mark Levinson 300 series start issues
I would just like to pass along some information on fixing start up issues on Mark Levinson 300 series amplifiers not due to output stage malfunction. Levinson has an engineering change order to address this issue by replacing IC U1 on the voltage gain board with LT1097CN8 opamp. It fixed a problem I was having with a 331 starting then turning off.
Old 3rd November 2019, 12:26 PM   #2
DanPe is offline DanPe
Hi willcycle,
Can you be more specific about the problem that you encountered?
I just bought a ML 331 and I'm going through all the ECO's that I found in the Service Manual and the replacement with LT1097CN8 is one of them.
Also, the ECO's mention part numbers for the replacement components but I cannot find these part numbers. This is needed to have the correct specs of these components. Can you help?
Greetings,
Daniel
Old 5th November 2019, 11:19 AM   #3
When coming out of standby after pressing the power button the amp would immediately shut off. The IC part number is the actual number.
Old 17th November 2019, 01:11 PM   #4
Hi Willcycle,
Thanks for your reply. Indeed IC number is clearly mentioned in the Service Manual but it also suggest to replace the Sprague 68 F 25 VDC capacitors (6 pieces) by part number (240-200013) but nowhere I can find more info of what is behind that part number.
Greetings,
Daniel
Old 17th November 2019, 09:29 PM   #5
rsavas is offline rsavas  Canada
We do not have much to work with, no schematic, no pics of the part in question, so hard to give advise.
Old 18th November 2019, 11:52 AM   #6
I replaced those 68 uF caps with equivalent Nichicon parts. I wouldn't be too concerned about a specific part here. Use 105 degree caps.
Old 18th November 2019, 08:22 PM   #7
Hello Willcycle & rsavas,
Thanks for your replies.
I add some more details: see the attachments.
Those Sprague 68 F 25 VDC are still available but they cost around 15 each. I'm just wondering why ML used 'special' caps for this and if I can replace them by just standard caps.
Greetings,
Danil
Fixing Mark Levinson 300 series start issuesHide this!Advertise here!
Mark Levinson No. 36 DAC,,,NEED HELP jc9394 Digital Line Level 2 7th October 2018 06:44 PM
Mark Levinson ML-3 jc9394 Solid State 2 3rd December 2017 05:18 PM
Mark Levinson ML-10 ARTISAND Analog Line Level 1 25th October 2016 08:24 AM
MARK LEVINSON 33X series caps..Whats best??? mclsound Solid State 1 9th March 2014 08:12 PM
Mark Levinson no:29 Snorkeltjes Solid State 19 24th November 2007 01:18 PM
Copyright ©1999-2019 diyAudio
