SSR for speaker protection?
Old 15th April 2019, 05:38 PM   #71
thimios is offline thimios  Greece
Originally Posted by prasi View Post
Hello thimios,
you never did speak to me about this!
Otherwise I would have made it earlier.
I stumbled here by chance while making APEX SSR protect.
Thanks to LKA for the design.
Still a rough design, need to see if binding post on a side can support PCB components. Otherwise , a hole for plastic standoff on the left side would provide necessary support for the PCB.
Prasi
Hi my friend!
I see you very busy and i don't want to stress you.
You are a pcb machine!
All the best for you and LKA
BTW if i will have the final schematic and the black&white pcb i can test this soon.
Old 16th April 2019, 12:44 AM   #72
jameshillj is offline jameshillj  Australia
Hi everyone,
Is there a simple safe way to add a 'mute switch' to this circuit? (with maybe an indicator led too?)
Old 16th April 2019, 06:45 AM   #73
prasi is offline prasi  India
prasi's Avatar
Originally Posted by thimios View Post
Hi my friend!
YOU can tell me anytime.
I will post black and white and the schematic, once I am done refining the design.
Pl note that this circuit is based on post no. 31 by LKA.
Prasi
My revamped site https://sites.google.com/site/analogdesign1234/
Old 16th April 2019, 07:26 AM   #74
LKA is online now LKA  Europe
Originally Posted by jameshillj View Post
Hi everyone,
See post 58, overcurrent circuit can be used as MUTE also. Just connect latching switch to terminal X4.
Old 16th April 2019, 08:31 AM   #75
Ah, simple indeed and easy to implement - a double pole switch for the indicator led too - thanks
Old 16th April 2019, 08:38 AM   #76
prasi's Avatar
Originally Posted by LKA View Post
Hi, You can leave out D1,D2 (or short them out).The detection threshold will be lower. If you want more symmetrical detection, just short out D2.
Thank you LKA for your suggestions. I will keep them on the pcb for the present. One could short or just remove D2 as per his preference.
Prasi
Old 16th April 2019, 08:53 AM   #77
Harry3 is online now Harry3  Australia
Hi Prasi
We appreciate your work.
Is it possible to get rid of the link that goes from the Mosfet to the speaker, with a track?
Old 16th April 2019, 08:57 AM   #78
Prasi
Another suggestion. Connect T5 collector to D3-D7 junction. C4 discharging will be quicker when AC is lost. (component numbering, post 65)
Check my last schematic, post 58.
Old 16th April 2019, 09:32 AM   #79
OnAudio is offline OnAudio
OnAudio's Avatar
Interesting thread, have been playing around with using arduino analog pins to check for DC and resolve within 100ms one might say that that is too slow considering above presumably detects and resolves in 380us. The AC lp filter 100k + 10uf will feature a 3.3 volt zener across the capacitor to protect the arduino input, other pins will check temp, over current and short circuit featuring lean code and timer interrupts. output pins will shut off power and trigger speaker protection, plus printing out on LCD the protection event.
Yes the analog domain is faster, however the digital domain is still fast enough.
onaudio.herokuapp.com
Old 16th April 2019, 09:59 AM   #80
I think that the photovoltaic optocoupler is more faster than this cny...
SSR for speaker protection?Hide this!Advertise here!
On speaker protection Keith Cary Chip Amps 3 9th February 2013 01:47 AM
speaker protection audiofan Solid State 0 19th February 2009 02:35 PM
speaker protection (OR) overload protection myanmar Solid State 7 13th July 2006 08:21 AM
FS: Niles HDS-6L speaker selector w/ speaker protection. Spasticteapot Swap Meet 0 27th May 2006 11:14 PM
Speaker Protection senee Solid State 0 17th May 2005 06:53 AM
Copyright ©1999-2019 diyAudio
