SSR for speaker protection?
Old 19th April 2019, 06:19 PM   #91
LKA is offline LKA  Europe
Originally Posted by prasi View Post
Hello LKA,
I put RS1,RS2,OK1 on protect pcb so that this SSR protect can be used on an existing power amp which does not have these components.
Prasi
I think this is not good idea. You create wide loop across emitter resistors.
Old 19th April 2019, 07:43 PM   #92
marcus1 is offline marcus1
Found this speaker protector device for sale from neurochrome:
Guardian-686: Speaker protection board for balanced, bridged, and BTL LM3886-based amplifiers (and others).
Any comments on how this design compares with whats being discussed here?
Old 20th April 2019, 11:47 AM   #93
prasi is online now prasi  India
prasi's Avatar
OK , thanks LKA, got it. then one need not populate rs1, rs2, ok1 and the sense connector, i.e, leave them out.
My revamped site https://sites.google.com/site/analogdesign1234/
Old 20th April 2019, 01:08 PM   #94
prasi's Avatar
Originally Posted by thimios View Post
BTW if i will have the final schematic and the black&white pcb i can test this soon.
Ready for pdfs?
Old 20th April 2019, 03:15 PM   #95
prasi's Avatar
here they are. rs1,rs2, ok1 on power amp pcb as recommended by LKA.
File Type: pdf SSR_LKA_REV1_bottom copper_top view.pdf (53.3 KB, 24 views)
Old Yesterday, 01:33 PM   #96
Mark Tillotson is online now Mark Tillotson
Here's my take on a speaker protect circuit that I designed a year ago or so, basically a discrete pair of SSRs. It has rail failure detection and DC detection for two channels, using mainly SMT. Optocouplers are miniature ACPL-217-500E's, MOSFETs are DMT10H010LK3, which are 100V and 6.5 milliohm. All fits on a board 2" square. Takes the main rails for power and has a test push button.
The detection circuitry is adapted from Doug Self's designs, but instead of driving a relay I drive an LED and two optocouplers.
The L and R grounds are allowed to float a bit w.r.t. each other and the supply ground.
Note the schematic needs some improvement, I've got the wrong symbol for the zeners (they are labelled with voltages though), and the wrong part number on the MOSFETs.
The key insight is how I float a zener/capacitor 12V supply between the rails with high value
resistors, which need to be sized to provide enough current for the resistor across gate & source when the opto-coupler is on.
The cross-connected 470k resistors are to give hysteresis to the switching, but I haven't yet tested or populated those, the basic protection function works without them.
SSR for speaker protection?Hide this!Advertise here!
On speaker protection Keith Cary Chip Amps 3 9th February 2013 01:47 AM
speaker protection audiofan Solid State 0 19th February 2009 02:35 PM
speaker protection (OR) overload protection myanmar Solid State 7 13th July 2006 08:21 AM
FS: Niles HDS-6L speaker selector w/ speaker protection. Spasticteapot Swap Meet 0 27th May 2006 11:14 PM
Speaker Protection senee Solid State 0 17th May 2005 06:53 AM
Copyright ©1999-2019 diyAudio
