Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier
Old 11th June 2019, 09:09 PM   #3201
danny_66 is offline danny_66  Belgium
danny_66's Avatar
Hi X,
I made a table last year,
here's the updated one with 0.15 sensor added, I settled on this version for 4R that I'll soon start building.
Code:
        | R131   | R132   | R128   |        |
        | source | sensor | ccs-fb | bias   | speakers
Alpha4R | 0.33   | 0.15   | 885    | 1.95A  | 4R-8R
Alpha20 | 0.33   | 0.12   | 680    | 1.95A  | 4R-8R
Alpha20 | 0.33   | 0.11   | 640    | 1.95A  | 4R-8R
Alpha20 | 0.44   | 0.12   | 510    | 1.46A  | 8R
Alpha20 | 0.44   | 0.11   | 480    | 1.46A  | 8R
Alpha4R | 0.27   | 0.12   | 860    | 2.38A  | 4R
Alpha4R | 0.27   | 0.11   | 790    | 2.38A  | 4R
If it is a 4R Alpha or a 8R Alpha is primarily defined by the R111 FB shunt resistor: 820R for 8R, 1k8-2k5 for 4R.
For a 4R you need minimum bias of 1.9A
Danny
My RefSpeaker v2
Old 11th June 2019, 09:16 PM   #3202
danny_66's Avatar
Originally Posted by Shawnstium View Post
Should R121 and R122 (R19 & R22 in the LTspice one you made) also be changed to 50R?
Definitely not, the two 50 ohm resistors are not in the original schematic, they're extra resistors parallel to R132,
so you can change the damping factor of the Alpha, see this post.
My RefSpeaker v2
Old 11th June 2019, 09:34 PM   #3203
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Thank you Danny! I added a link to Post 1.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 11th June 2019, 10:03 PM   #3204
AKSA is offline AKSA  Australia
And thanks from me too Danny. This is very good table for the ALPHA 20 and gives it terrific versatility..
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 12th June 2019, 08:09 PM   #3205
Shawnstium is offline Shawnstium  United States
Whoa, those are really small changes in the resistor values and it makes my head spin! Are you measuring the resistors before installing them or are those the values listed on the parts you purchased/simulated? What kind of tolerances and temp coefficients are you using?
What do the different values of the CCS FB R128 do for the circuit?
I recall you posting a table (copied below) with different cap values for the different FB shunt R111. My guess is the cap values effects the gain in the VAS portion of the amp, with a higher value giving more gain. How did you come up with those recommend ratios and again what kind of tolerances are you looking at?
Gain settings: max. Vin for 17 Vout (max power):
Alpha20 with shunt fb 820r: 0.69 Vin
Alpha4R with shunt fb 1k8+68uf: 1.45 Vin
Alpha4R with shunt fb 2k2+56uf: 1.74 Vin (recommended, ratio H1-15/H1-4 = 99.74)
Alpha4R with shunt fb 2k7+47uf: 2.09 Vin
The FFT profile of the Alpha4R 2k2 looks a lot like the Alpha20 8R.
Old 12th June 2019, 09:50 PM   #3206
Got Foam?
xrk971's Avatar
The ABBB GB thread has been started:
The Alpha Big Boy with Buttah (ABBB) 52w Class A Amp GB
Old 12th June 2019, 10:40 PM   #3207
Shawnstium,
These are simulated values and they work well on the prototype. Not all these are tried, but they will always work well. In particular, the difficult value is R128, the fb CCS resistor. None of the values given in Danny's table alter the gain of the amplifier, which is set solely by R113 and R111 (22k/820R). These should be 1% tolerance.
R128 equalises the antiphase currents in the output devices so they show identical dynamic range, a few tens of mA to about 3.5A each at max output into 8R. Different for 4R load of course. These values are given, but it can be examined on a dual beam CRO at max output with a load. But they are easily derived using simulation, and they are accurate.
This is an open source amp. You are invited to build and play, and if you discover something significant, as Danny did, put it up and we will have a look at it. This amp is extremely tolerant of 'fiddling' and gives a consistent, almost invariant harmonic profile across many versions.
HD
www.aksaonline.com
Old 12th June 2019, 11:50 PM   #3208
Thank you for the feed back. I have started the build of the 4R using 22k/2.2k for R113 and R111. Iíll try a couple values for the bypass cap for R111 and maybe a few R in 128.
File Type: jpg 66FA5A44-67BA-4B9B-93D8-DFEA0DE1584E.jpg (996.2 KB, 182 views)
Old 13th June 2019, 03:42 AM   #3209
Vunce is offline Vunce  United States
Hello Alpha Builders,
Iíve remodeled my Alpha20 to utilize the new SLB psu and also added a regulated linear psu to power the PWM fan controller.
Iím happy to report that the ďremodelĒ was well worth it! The amplifier is much quieter at idle, almost silent. Revisiting this project has me thinking that Iíll build another set of boards following one of Dannyís 1.95A, 4R/8R models. (Thanks for all the Alpha20 modeling youíve done )
Vunce
File Type: jpg 16350C83-C3E9-4B48-B004-DED133AA1D93.jpg (1.01 MB, 207 views)
File Type: jpg 5F41A547-B598-4F77-9CD2-A3398B5ACE7A.jpg (994.1 KB, 178 views)
File Type: jpg 2533BCED-CD49-4043-AFBC-354C827A73BC.jpg (944.3 KB, 179 views)
File Type: jpg A5DEAA3F-DFC3-4B66-9BED-B9C074E17C1B.jpg (978.8 KB, 381 views)
Old 13th June 2019, 05:12 AM   #3210
Got Foam?
xrk971's Avatar
Nice work, Vunce!
Is that the nice super flexible 16ga silicone insulation RC model car wiring you are using between the SLB and the amps? Looks very low strain for how thick they are.
Aksa Lender P-mos Hybrid Aleph (ALPHA) AmplifierHide this!Advertise here!
AKSA's Lender Preamp with 40Vpp Ouput GB xrk971 Group Buys 436 24th June 2019 06:47 PM
AKSA's Lender Preamp with 40Vpp Output xrk971 Analog Line Level 1102 31st May 2019 05:27 AM
Aksa Lender HPA xrk971 Headphone Systems 114 22nd April 2019 02:02 PM
Help newbie with low budget Magnificat/MLTL hybrid project AN8 + Eminence Alpha 10? klykx Full Range 1 9th October 2006 03:22 PM
AKSA vs Aleph or Aleph-X Prune Pass Labs 20 11th March 2004 03:05 PM
Copyright ©1999-2019 diyAudio
