Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier
Old 14th February 2019, 11:46 AM   #3071
alephotos is offline alephotos  Italy
Hi, I have 4 aluminum radiators of 250x132x40 mm (about 9.842x5.197x1.575 inches) each, which weigh 1673 gr (about 3.690 Lb) each, are sufficient for the 20w version? Adding fans could be used for the big boy version?
Old 14th February 2019, 02:51 PM   #3072
antoniopf1972 is online now antoniopf1972  Spain
Hello my name is Antonio. I live in the south of Spain, in Malaga. I'd like to do an alpha BB. Although Maty already warned me that produces a lot of heat and here where I live 15 degrees in winter and 30 or 32 in summer. That HP radiators with fan I recommend to cool as much as possible and not make a lot of noise. My level of English is bad, if you do not understand something of what I say is by the translator of Google.What radiator do I buy? To remove the maximum heat possible. A greeting
Old 14th February 2019, 04:00 PM   #3073
zman01 is offline zman01  Bangladesh
Antonio,
Welcome to the ALPHA thread!
One of the minds behind the ALPHA BB, xrk971 uses the cooler described (with link) in this post:
Maybe X can chime in too.
Old 14th February 2019, 11:25 PM   #3074
Thank you. For the welcome. I have already contacted xrk971 and given me some tips on fan. See if I like them. Now to look for components over the Internet. I have work ahead hehe
Old 16th February 2019, 05:20 PM   #3075
This is the item
Old 16th February 2019, 06:48 PM   #3076
I have 4 Dell server which I think will go well with fan.
Old 16th February 2019, 07:14 PM   #3077
I would like to make the 20 w version, is the PCB still available? Or the gerber file for the PCB?
Old 16th February 2019, 07:28 PM   #3078
Vunce is offline Vunce  United States
Hello Alephotos,
Yes, the ALPHA20 and BB pcbs are available here:
XRKaudio https://www.etsy.com/shop/XRKAudio
Aksa Lender P-mos Hybrid Aleph (ALPHA) AmplifierHide this!Advertise here!
Aksa Lender HPA xrk971 Headphone Systems 78 Today 08:02 PM
AKSA's Lender Preamp with 40Vpp Output xrk971 Analog Line Level 1056 20th February 2019 07:56 PM
AKSA's Lender Preamp with 40Vpp Ouput GB xrk971 Group Buys 427 11th January 2019 05:21 AM
Help newbie with low budget Magnificat/MLTL hybrid project AN8 + Eminence Alpha 10? klykx Full Range 1 9th October 2006 04:22 PM
AKSA vs Aleph or Aleph-X Prune Pass Labs 20 11th March 2004 04:05 PM
Copyright ©1999-2019 diyAudio
