Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier
Old 29th January 2019, 10:13 AM   #3061
Mleod is offline Mleod  Italy
Greetings to all,
the BB with low impedance loads, 1-3 ohms, how does it behave? ... distortion, power supply, etc. but not the last sound and harmonic aspect.
Thank you. HELLO
Mleod
Old 29th January 2019, 09:10 PM   #3062
AKSA is offline AKSA  Australia
These loads are below the designed parameters. I designed if for 4R loads, to go no lower than 3R. Your figures are so low that indicate a ribbon speaker with pure resistive loading.
HD
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 30th January 2019, 01:05 AM   #3063
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Add a 2ohm resistor?
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 12th February 2019, 01:39 AM   #3064
drpro is offline drpro  United States
X, I have a question regarding the BB. I have my boards and supplies completed. Fired everything up, found a builder error, so no sound yet. I have repaired my error and before applying power again, I doubled checked to make sure the CPU cooler was not connected to the boards by the bolts.
In my checking I discovered both the V+ and V- tabs appear to be connected to the vias that are right above them. I am using an ohm meter to check. This is true of both boards I have constructed.
Is this normal?
David
I must build. Pass F4s, F6, M2, BA-3 preamp, MoFo, ImPasse preamp, Whammy headamp, Aksa's Lender preamp, Salas DCG3 headphone/preamp, XRK971 PCA & DCA headamp Bruno Putzey's balanced preamp, Doug Self preamp, Pete Millet Korg headamp.
Old 12th February 2019, 02:17 AM   #3065
wtl is offline wtl  Australia
Dave,
I checked my BB boards (unpopulated) and yes they are connected to the vias above them.
Steve.
Old 12th February 2019, 03:32 AM   #3066
Thanks Steve. That is reassuring, not losing my mind here!!
Old 12th February 2019, 05:36 AM   #3067
Hugh, I found and corrected my build error. I powered one of the boards and was able to play some music through it, however at a very low level. I am guessing due to my construction error and powering the board I burnt out the two KSA992 transistors (V101 & V105)
Would I be correct in understanding the circuit that these two transistors supply the initial amplification?
David
Old 12th February 2019, 08:22 AM   #3068
Got Foam?
xrk971's Avatar
Hi DrPro,
Sorry to hear your BB had some shorts due to vias. I think I mentioned that in the thread that CPU coolers needed insulating washers to prevent a short. I used felt washers. Always a good idea to check for shorts between a heatsink and rails with DMM before adding power. Was that your build error? If so, normally just blows fuses on the PSU. The amp normally survives that as current is shunted straight to ground - or from positive to negative rail and doesn’t flow through components.
Main thing to check: are you getting the usual 3A of bias current through the MOSFETs? Measure voltage across R145/6/7 - should have 3A and they will be warm. MOSFETs will be warm.
If weak sound, then maybe input connection is bad or reversed in polarity?
Next is check if you have about 2mA bias current through the LTP. Measure acrosss R104.
If both above are good, you should have sound.
Other possible thing to check is V111, sometimes that can get damaged or is wrong sex. Then you won’t have bias current and DC offset is huge(24V) in one direction but MOSFETs not hot.
Old 12th February 2019, 02:28 PM   #3069
Thanks X for the insights. I will check all after work today.
Old 12th February 2019, 05:33 PM   #3070
Had a moment X.
Measured from the outs of the Cap MX. Adjusted based on Hugh's suggestion.
+V = 37.3
-V = 40.2
Across the R145/6/7 combo
.6vdc
with about 2.75a bias
Across R104
11.5vdc
with about 3.5ma bias
No other observed issues, so I will check V111 when I get home.
David
Aksa Lender P-mos Hybrid Aleph (ALPHA) AmplifierHide this!Advertise here!
Aksa Lender HPA xrk971 Headphone Systems 76 Yesterday 06:24 PM
AKSA's Lender Preamp with 40Vpp Output xrk971 Analog Line Level 1054 Yesterday 02:44 AM
AKSA's Lender Preamp with 40Vpp Ouput GB xrk971 Group Buys 427 11th January 2019 05:21 AM
Help newbie with low budget Magnificat/MLTL hybrid project AN8 + Eminence Alpha 10? klykx Full Range 1 9th October 2006 04:22 PM
AKSA vs Aleph or Aleph-X Prune Pass Labs 20 11th March 2004 04:05 PM
Copyright ©1999-2019 diyAudio
