Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier
Old 12th October 2018, 07:02 AM   #2841
Juntuin is online now Juntuin  Finland
Thanks zman! That's the way to go
Old 12th October 2018, 02:33 PM   #2842
jwjarch is offline jwjarch  United States
jwjarch's Avatar
Wow Juntuin! Impressive to say the least!!!
Old 12th October 2018, 03:58 PM   #2843
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Juntuin,
Holy moly, that's just way over the top!
Congrats on a beautiful looking and sounding setup.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 12th October 2018, 04:06 PM   #2844
Thanks guys . I think that B.B. is best amp so far I have heard, it seems that my friend will take mine to his system. Maybe I'll have to build another one, as passive cooled..don't know, lacking motivation (and extra money) right now.
Would there be too much concentrated heat with huge passive heatsink, since we are using only two devices per amplifier?
Old 12th October 2018, 06:47 PM   #2845
Got Foam?
xrk971's Avatar
You need a cpu heat pipe spreader to take the high flux of 100w/3cm^2 out to a larger area. Maybe take a CPU cooler with heat pipes and remove the fins. Then sweat braze the copper pipes to a copper plate. Then bolt the plate to a large radiator. The larger the area of spread on the pipes the better. You can also order bare heat pipes and make your own - it’s more expensive though that way.
Old 12th October 2018, 07:03 PM   #2846
Ok, I won't do it then next one will be something simple and traditional.
Old 13th October 2018, 04:19 AM   #2847
carlthess40 is offline carlthess40  United States
What would it cost for you to build a two channel amp without and cooling or case ? I would be able to do all of that and I would like to water cool it.
Old 13th October 2018, 06:19 AM   #2848
Got Foam?
xrk971's Avatar
Is this for Alpha 20 or B.B. and do you mean just populate the boards with all parts? Are you asking to have the power supply included as well?
Old 13th October 2018, 07:50 AM   #2849
I think the Alpha 20.
It is the cheapest of the two to build?
Iíve tried reading though all of this post, and as you know itís a great and long post to read. But my goal is two channels and cost
Old 13th October 2018, 07:53 AM   #2850
Maybe it would help if we could talk over the phone about this one day. Message me and Iíll send you my info
Carl
Aksa Lender P-mos Hybrid Aleph (ALPHA) AmplifierHide this!Advertise here!
AKSA's Lender Preamp with 40Vpp Ouput GB xrk971 Group Buys 407 6th October 2018 08:48 AM
AKSA's Lender Preamp with 40Vpp Output xrk971 Analog Line Level 860 2nd October 2018 08:27 AM
Aksa Lender HPA xrk971 Headphone Systems 50 30th August 2018 01:26 PM
Help newbie with low budget Magnificat/MLTL hybrid project AN8 + Eminence Alpha 10? klykx Full Range 1 9th October 2006 03:22 PM
AKSA vs Aleph or Aleph-X Prune Pass Labs 20 11th March 2004 03:05 PM
