Hi,I incorporated your feedback from your build into the latest document bambadoo - should be up to date.
Wolletje, V1.0 boards are quite old - there were a few component value changes IIRC after that. Where did you get you boards from?
Here is the link to the sx-Amp article Ovation sx-Amplifier: A High Performance 15 W Class A Current Feedback Amplifier
If you have questions, just email me.
Thanks for the information.
Mabey there will be more from this diyaudio.
I hope hifisonic can help me also with this project with information.
I left a message there.
With regards Frits
I have a question about Q3 and the solution mentioned by bambadoo. I saw a picture with a short from leg basis Q3 to R20 and a photo with a connection to R21. I do not understand witch of both is the solution or is the R20 with the 2.2/2.4K the solution for the Q3?
The C2 SMD on the amp circuit. This one not solder?
With regards, Frits
With regards, Frits
SX amplifier 2012 V10 version pictures
Wolletjr,
Please send me a picture of your PCB.
All the components for the sx amp are arrived a time ago and I like to start soldering but I am very very unsure about this last point and I need a solution for this point. I did not see a solution for this question yet.
There is a picture I got from Bambadoo e-mail, there is a jumper wire from Q3 (BC547C) to resistor R20 (R21 ?). Do I solder this jumper? Instead BC547C I use BC550C. But I suppose that's no big difference for this point.
I am happy with any help in making this amplifier. Thanks, Frits
Use 2W resistor in R9 position.Hi Andrew,
I have soldered the most parts on the amplifier circuit but there is one resistor I do not understand R9:.... 3.3R 2W on the circuit and in the BOM list 3.3R 0.5W . Can I use the 2W or the 0.5W? This is a flame resistant resistor?
With regards Frits
Thanks all, very helpful
Another questions:
1) The fuses 5A on the amp board? I cannot find if they must be slow (T) or fast (F) fuses?
2a) On mine version PSU are two rectifiers. Should I provide them with a cooling radiator?
2b) And I have to solder a 10nF 100V capacitor(s?) on the bottom of the PSU. I think from J3 (GND) to J14/J4 (OVC) but that is a great distance (50mm) on mine board. Is this right or is there another solution. I can extend the legs of the capacitors.
With regards, Frits
Another questions:
With regards, Frits
- ovation sx amplifier
