ADA4625-- 3.3nV/Rt Hz JFET opamp
Email from Analog this morning -- I guess the part has been out since late last year: http://www.analog.com/media/en/technical-documentation/data-sheets/ADA4625-1.pdf
what about sound quality in RIAA preamplifiers ?
Maybe perfect, if an additional buffer (e. g. a discrete single ended source follower stage) is added.
Idle current only 4mA for the whole OPA and no internal output buffer like AD797 - for internal simplyfied schematics go to page 11 under
http://www.analog.com/media/en/technical-documentation/data-sheets/AD797.pdf
and page 21 under
AX tech editor
Joined 2002
It says:
*Not modeled: Distortion, PSRR, Overload Recovery,
* Shutdown Turn On/Turn Off time
*Parameters modeled include:
* Vos, Ibias, Input CM limits and Typ output voltge swing over full supply range,
* Open Loop Gain & Phase, Slew Rate, Output current limits, Voltage & Current Noise over temp,
* Capacitive load drive, Quiescent and dynamic supply currents,
* Shut Down pin functionality where applicable,
* Single supply & offset supply functionality.
Administrator
Joined 2007
They do cite a THD% statistic of 0.0003% under certain conditions.
Expensive chip, not as expensive as OPA637, however. Fetishists will be disappointed that there isn't a TO-99 version!
So its not going to fit on my S-DEC then. Rats !
attachment.php
