OK, cool - it's better to measure at TP2 - same shape but higher amplitude - less noise. Very good in terms of phase alignment.
It looks like you didn't reach the minimum - if the trimmer is at its limit - amend the value of the resistor that is in series with it.
The green one will go down to some 100mV RMS and become somewhat corrupted - then that's a pure error signal.
Hi jeff, are you using any thermal paste between this and heatsink?I'm using CD-02-05-264 Wakefield-Vette | Mouser Canada. I used 43-77-20G Aavid | Mouser Canada in the past but found them a bit too fragile.
I mean for the 567-cd-02-05_264
Hi Valery, how critical is the C18= 27pf?
I found a ceramic 27pf common type and a 33pf NPO.
This will be just for test, then i will order the right type.
The same for C11=10pf.I found a ceramic 10pf NPO.
I'm in a hurry to listen the Simpelstark in stereo mode.
Wakefield recommends using this in place of thermal paste. Just bolt it up dry, it'll melt onto the surfaces as soon as things warm up.
- No-global-loop amplification
