JLH 10 Watt class A amplifier
Thread Tools
Old 6th June 2021, 02:28 PM   #8061
hanair is offline hanair  United States
Looks like my amp is oscillating even with TIP41C. Anybody here used the following PCB with any NPN power transistors? Next I need to replace my switched power supply with a regular one.
Old 6th June 2021, 04:12 PM   #8062
OldDIY is offline OldDIY
2sc2705 e-k-b npn https://static.chipdip.ru/lib/310/DOC000310064.pdf
2sa970 e-k-b pnp https://static.chipdip.ru/lib/947/DOC005947869.pdf
Old 7th June 2021, 02:33 AM   #8063
I could remove oscillations by shorting R1. R1 is in series with the input coupling capacitor (coupling capacitor is C1 on this board which is actually C4 in JLH's original schematic). I used some arbitrary (but low k) for R1 and apparently that is not required as per JLH! Before I can test it with speakers, I need to re-assemble the board that I was playing around with.
Old 14th June 2021, 09:41 AM   #8064
bistvan1980 is offline bistvan1980  Hungary
bistvan1980's Avatar
Default Join the team.
Hello! I will join the team.
Original Motorola 2N3773 is the output. (saved from old industrial power supply)
My test version schematic:
Old 14th June 2021, 11:26 AM   #8065
At 12V and 8 ohms, it is enough to set the current to 0.8-0.9 A. The power will be 1.5 watts.
Some used BD911.
MJE13007 can also be used at the output. For a driver, their characteristics are not quite suitable. But it will work)))
Old 14th June 2021, 11:47 AM   #8066
Hello! It is currently in an experimental phase.
I haven’t measured it yet, I roughly calculated 4W music peak power.
I put it together quickly based on the circuit diagram.
It sounds good and 1.5W RMS is enough for me. I'll replace the transistor in it, that's all it was at home.
I'm sending some pictures:
Old 14th June 2021, 12:00 PM   #8067
Suitable radiators, correct position (vertical). If you want and use a more powerful power supply and a higher voltage (up to 27 V), you can build an amplifier according to the author's specification.
Old 14th June 2021, 12:11 PM   #8068
The 24Vac can be used with these transformers. Can be used up to 2.5A.
Voltage regulator is not a problem. LM317T (or 7824 (?)) with PNP power transistor.
I'm interested in the thing.
I have 6pcs 100VA 230V/30Vac hypersil transformer. 30Vac is too much, I can to make lower voltages.
Old 14th June 2021, 12:37 PM   #8069
24V AC will give 32V DC (no load). The surplus can be used to operate a stabilizer or a capacitance multiplier. Or DC-DC converter.
Old 14th June 2021, 01:36 PM   #8070
Maybe unwind from the secondary to about 22Vac(100VA 30V hypersil).
I am thinking hard about bringing step-down SMPS into the system.
Result: negative. 3-7V drop analog regulator is more sympathetic.
IQ=1,3A is enough for 24V(dc) stable / 10W 8 Ohm?
JLH 10 Watt class A amplifierHide this!Advertise here!
Thread Tools
20 Watt Class A amplifier JOE DIRT® Solid State 8 31st January 2012 11:41 PM
JLH 10 Watt class A amplifier DomKo Solid State 3 18th November 2003 06:32 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
