JLH 10 Watt class A amplifier
Old Yesterday, 02:13 PM   #5151
Bigun is offline Bigun  Canada
Bigun's Avatar
I've also been thinking about putting some drivers in my JLH, turning the outputs into discrete Darlington pairs in order to reduce the impact of beta droop on the 'phase splitter' device sitting at the heart of the amplifier.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old Yesterday, 04:32 PM   #5152
fredbloggstwo is offline fredbloggstwo  United Kingdom
Hi Bigun,
this might give you some food for thought.
JLH-D16
Cheers
Mike
Old Yesterday, 10:47 PM   #5153
Bigun's Avatar
Thanks ! - - pitty you didn't use 2N3055's but overall the results are a vote in favour of discrete Darlington!
Old Today, 01:05 AM   #5154
thoglette is offline thoglette  Australia
thoglette's Avatar
Originally Posted by nigel pearson View Post
For years I have wondered why the Peter Blomley 1971 amplifier design never attracted comment. All the sage and intellectual advisors seem to have avoided it. I suspect it is simply soar grapes.
I think also because the architecture never made it into the text books - as an EE student in the eighties I designed and built a similar (but fatally flawed) amplifier that my supervisors considered completely novel.
And this was in a university at the cutting edge of microelectronics design.
I wish I'd seen Blomley's paper before hand!
Old Today, 09:10 AM   #5155
nigel pearson is offline nigel pearson  United Kingdom
Very good points raised. The Blomley seems worth tying if the supporters comments are true.
I find it a miracle the JLH can drive the output transistors as well as it does. I take the point about > 20 kHz working. As Lars at Nordost says " Humans do not hear to 20 kHz usually, However they do detect waveform shape of a filtered signal that rolls off above 20 kHz", that's as best as I remember.
Although we talked about it before. My BC327/337-40 2N3055 Indian JLH needed to drop at 160 kHz -3dB full power. Before fitting 33 pF that I suspect could have been smaller ( 10 to 22 pF ? ) a small rise in output was seen between 500 kHz and 2 MHz in the noise floor with no 33 pF fitted. It was about 3 dB at perhaps 1.5 MHz peak, it was mildly modulated. The drop at 2 MHz was steep which I took to be the ft plus other factors. I didn't try the unlimited version. Some say mildly unstable amps sound better, maybe? The argument is music is different and appreciates not having the corner removed. A slightly overshooting square wave ( no output choke ) in that theory is best as long as the amplifier recovers quickly. I have no idea if that is right.
JLH 10 Watt class A amplifierHide this!Advertise here!
20 Watt Class A amplifier JOE DIRTŪ Solid State 8 31st January 2012 11:41 PM
JLH 10 Watt class A amplifier DomKo Solid State 3 18th November 2003 06:32 AM
