DIY Class AB SS Amplifiers Top List
most DIYer's have analysis paralysis, this list is going to be a problem for them !
It would make the list a lot more complex but it would be cool if there were indicators as to difficulty level, if pcbs are available and if they use any hard to find parts. A way for people to eliminate options quickly to narrow their version of the list.
Where does the Self Blameless amplifier fit into this?
The Self Blameless Amplifier is not an amplifier design, it is a concept. Self implements the concept using a two stage amplifier (like the Honey Badger), but that does not mean every two stage amplifier is a blameless amp. Below is an excerpt from Self's book.
The Concept of the Blameless Amplifier
Here I introduce the concept of what I have chosen to call a Blameless audio power amplifier. This is an amplifier designed so that all the easily defeated distortion mechanisms have been rendered negligible. (Note that the word Blameless has been carefully chosen not to imply perfection, but
merely the avoidance of known errors.) Such an amplifier gives about 0.0005% THD at 1 kHz and approximately 0.003% at 10 kHz when driving 8 Ω . This is much less THD than a Class-B amplifier is normally expected to produce, but the performance is repeatable, predictable, and definitely does not require large global feedback factors.
Thank you for all your contributions.I think the list will expand further and very useful for diyers.
  1. The diyAB "Honey Badger"
  2. Leach Amp [v4.5, Superamp]
  3. Slewmaster - CFA vs. VFA "Rumble"
  4. AMB Lab β24 fully-differential power amplifier
  5. Rod Elliot P3A
  6. AKSA 55
  7. Circlophone© by Elvee
  8. MikeB's Symasym
  9. David Tilbrook's AEM6000
  10. Fetzilla
  11. Apex FH9 Xrk mode
  12. Roenders FC100
  13. Cubie3
  14. DX Blame
  15. VSSA
  16. VHex
  17. Symef
  18. Quasi's Nmos200
  19. Very Simple Quasi Complimentary MOSFET Amp
  20. Vzaichenko's Vertical CFA-Non Switching Output Stage
  21. Vzaichenko's Tubesumo Amp
  22. Vzaichenko's Other Projects !
  23. Apex SR50 and SR200 ( I didn't listen these systems but maybe anybody can share their experience )
  24. Astx - SA2014 BJT (200W@8R, 400W@4R) 8 pairs TTC5200 and TTA1943
  25. Astx - SA2015 V-MOSFET (70W@8R, 140W@4R) 3 pairs IRFP240 and IRFP9240
  26. Astx - SA2015 V-MOSFET (100W@8R, 200W@4R) 1 pair IXTH80N20L and IXTH48P20P
  27. Astx - SA2016 L-MOSFET (70W@8R, 140W@4R) 3 pairs ECX10N20 and ECX10P20
  28. Astx - SA2016 L-MOSFET (100W@8R, 200W@4R) 3 pairs ECW20N20 and ECW20P20
  29. NAP-140
  30. Ovation SX and NX
  31. SC200 Silicon Chip Magazine http://www.siliconchip.com.au/Issue/2017/February/New+SC200+Audio+Amplifier+–+Part+2?res=nonflash
  5. Rod Elliot P3A
  6. AKSA 55
  8. MikeB's Symasym
  10. Fetzilla
  12. Roenders FC100
  13. Cubie3
  14. DX Blame
  15. VSSA
  16. VHex
  17. Symef
  18. Quasi's Nmos200
  29. NAP-140
  31. TGM8 - an amplifier based on Rod Elliot P3a
  32. PeeCeeBee V4H
  33. SC200 Silicon Chip Magazine
  34. Peter Blomley's Non-switching Class B amplifier
Performing simulations and all that nonsense with models of parts that you have no idea is even close to real world is absolutely useless if you want to know if the amp is any good.
A simulation gives you only some indication that in a perfect environment the circuit will work - how well is the question.
Sometimes you want blind people to listen and compare the performance - even more BS.
