Meridian 103 clone
Meridian 103 clone
Old 10th April 2019, 03:53 PM   #51
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Meridian 103 clone
Maybe... probably more impact in the bass.... let us know the outcome
RC
Old 10th April 2019, 04:29 PM   #52
keantoken is offline keantoken  United States
keantoken's Avatar
I can't determine what D2 and D4 are for, but I would think they have something to do with tuning the amp behavior during startup or prolonged clipping. They seem to be keeping the input transistors slightly on at low supply voltages. They could also be affecting temperature compensation.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 10th April 2019, 07:27 PM   #53
nhinstruments
RCruz's Avatar
Meridian 103 clone
Thank you kean.
Please view the last mods that increased damping at low freq apart from your suggestions.
File Type: asc Meridian 103 exicon power amp EVO13 DAMPING FACTOR.asc (15.8 KB, 19 views)
RC
Old 10th April 2019, 08:00 PM   #54
phase is offline phase  United States
Originally Posted by keantoken View Post
The funny thing about lytics is that they usually already have a 10nF or so cap inside them which bypasses the ESR at high enough frequencies where the oxide layer behaves more like a dielectric than a conductor.
I have never heard such a tale, where do you get your information, I am curious?
Old 10th April 2019, 09:00 PM   #55
keantoken's Avatar
It is there in some obscure capacitor manufacturer app notes which discuss the electrolytic equivalent model to higher detail. If you measure the ESR of a lytic you will find it starts to decrease above a certain frequency. You can see it here on page 8:
http://www.hoffmann-hochfrequenz.de/...capacitors.pdf
In this case it's more like 1nF, but it's still there. It looks like I didn't save the original references.
Old 13th April 2019, 01:25 PM   #56
nhinstruments
RCruz's Avatar
Meridian 103 clone
New work done.
Jfet cascoded IPS
IPS bias now set with CCS found here: TSSA - The Simplest Symmetrical Amplifier
Needed to reduce lead lag capacitor in the feedback loop to retain a good phase lag.
That also increased bandwidth and -3dB is now near 300khz.
IPS emitter decoupling capacitors where increased to 1000u.
THD reduced from 0.005 to 0.0035% ...
Now my question is... can I use 62V rails with only two output lateral mosfets per rail or should I reduce voltage ?
Is it normal that I find a damping factor of 33000 at 1khz ?
Output impedance is 247uohm at 1khz .... never simed nothing like it before.
RC
Old 15th April 2019, 06:15 PM   #57
nhinstruments
RCruz's Avatar
Meridian 103 clone
Adding an output coil and damping resistor lowers damping to lower than optimal damping....
File Type: png MClone Damping factor @ 20kHz With output coil.PNG (113.6 KB, 57 views)
RC
Old 15th April 2019, 06:20 PM   #58
nhinstruments
RCruz's Avatar
Meridian 103 clone
Adjusted bias current to much lower and acceptable values.
Adding some additional info for those who do not have the models.
Just place everything in the same directory and open with LTSpice....
File Type: asc Meridian 103 exicon power amp EVO15 CCS IPS CASCODE TRANSIENT.asc (18.4 KB, 7 views)
RC
Old 15th April 2019, 06:22 PM   #59
nhinstruments
RCruz's Avatar
Meridian 103 clone
Trying zip with TL431 files to be dropped on the same directory...
File Type: zip TL431.zip (780 Bytes, 5 views)
RC
Old 15th April 2019, 07:45 PM   #60
keantoken's Avatar
Output impedance can be down in the uohms depending on the feedback, but this is moot as one inch of wire swamps it out.
At 20KHz there is nothing to damp, the speaker parasitics are preventing any damping from taking place through the voicecoil at those frequencies. If you look at the numbers, the more likely reason if the output inductor affects sound is that it causes some HF rolloff. And/or it is preventing oscillation or RF demodulation.
Meridian 103 cloneHide this!Advertise here!
Meridian M2 clone - driver recommendations 68Spider Multi-Way 26 30th August 2016 07:20 PM
JVBDigital Vanity Lite 103 full resolution digital output board for Oppo BDP-103/103D noah katz Swap Meet 1 20th June 2015 10:47 PM
Meridian 103 overheating Impman71 Solid State 7 10th April 2012 10:15 AM
Can Anyone Identify This Component in Meridian 103/5 Power Amps Please? Thomo Solid State 13 26th April 2010 11:39 AM
Meridian 103 - bdy56 Transistor Alternatives? Thomo Parts 11 25th February 2008 02:26 PM
Copyright ©1999-2019 diyAudio
