Rebuilding power amp. Questions about resistor types.  Fail safe and others
Old 13th March 2017, 08:20 PM   #11
hahfran is offline hahfran  Germany
if you can get these ...nothing compares http://www.isabellenhuette.de/filead...taende/PBH.PDF has English specs text column
Old 18th March 2017, 06:02 PM   #12
Richard_James is offline Richard_James
Anyother thoughts on fail safe resistors? Do they use them any more.. what makes a resistor worthy that "fail safe" label. It does not cause fires? Can I use regular metal film resistors instead?
Old 13th June 2019, 08:13 AM   #13
kecapmanis021 is offline kecapmanis021  Indonesia
kecapmanis021's Avatar
RC = Cement Resistor. Japanese gear commonly use Futaba or Noble non-inductive cement resistor as emitter resistor. They are usually white square shape. Rather difficult to source. Substitution is Koa Speer type BPR.
Failsafe resistor also known as Fusible Resistor, it has a fuse which will blow/open when exceeding wattage rating.
There are several threads in audiokarma.org about this Fusible Resistor. You can look it up. Hope it might help.
~Kecap
Rebuilding power amp. Questions about resistor types.  Fail safe and othersHide this!Advertise here!
Fail Safe Power Supply Allen Newby Pass Labs 46 26th August 2014 05:55 PM
Many questions on mhennessy's Hi-Fi preamp (mainly about power-fail detect circuit) jarsoffart Analog Line Level 9 5th March 2012 09:38 AM
Rebuilding Soundcraftsman amp. Need advice, ID burnt resistor??? Pix attached... jmlandry Solid State 1 2nd June 2010 05:59 PM
Cap and resistor types in guitar tube amp voivodata Instruments and Amps 12 28th April 2007 07:24 PM
Copyright ©1999-2019 diyAudio
