old Pioneer will only play music in direct mode
old Pioneer will only play music in direct mode Please consider donating to help us continue to serve you.
Old 7th March 2017, 01:40 PM   #1
gentlejax2 is offline gentlejax2  United States
Default old Pioneer will only play music in direct mode
I have a Pioneer VSX-9900s which is the last unit before the first Elite but basically the same as the first Elite. It plays fine out of both channels but only in "direct" mode. if i click dolby or and other sound feature I get immediate screatching and static. but then when I go back to "direct" it goes to normal stereo.
anyone have any knowledge of this? there is a VSX-D1 on ebay that is doing the same thing. I am guessing this is common with these
Old 7th March 2017, 05:50 PM   #2
ief is offline ief  Netherlands
ief's Avatar
Wouldn't suprise me if it is a power supply issue of some sort. No garanties though.
Old 7th March 2017, 06:21 PM   #3
how would it run fine if the tone controls are bypassed ? if the power supply were shot? I dont know...just seems odd
it plays fine until I hit dolby or any of the sound enhancements.
Old 7th March 2017, 06:35 PM   #4
ief's Avatar
For that you have to dive into the schematics, quite daunting
The digital section is the least forgiving of bad/ dirty power supply. So, that's why I suggest that as a good option. In direkt mode all that is bypassed, hence sound.
Depending on make and model offcourse, I have an onkyo and that just muted the audio all together, lifted that and at least able to use direct again.
Old 8th March 2017, 11:21 AM   #5
sgrossklass is offline sgrossklass  Germany
There also are a lot of ribbon cables running around in this unit, if those are the plug-in type (rather than soldered) some reseating action may work wonders.
But yeah, do check supplies for the digital section, starting with digital +5V. Supply might be low (JRC regs are known to go bad once in a while), or the reg might be oscillating because the electrolytic on the output is dried out.
This unit is quite complex and advanced for the day - having a DSP in there was not at all common back in 1991, most manufacturers only started doing this in the mid-'90s.
old Pioneer will only play music in direct modeHide this!Advertise here!
Does anybody still play music cassettes? Sam GT Analogue Source 92 2nd January 2020 04:26 PM
Music player to play from a network drive? thyristor44 PC Based 7 15th May 2015 09:40 PM
How to play SACD in surround mode? anubiz84 Digital Source 0 27th March 2014 04:48 AM
Amp to play music from laptop erukus Solid State 24 7th March 2012 05:07 PM
What music cd's/Lp's get most play? DaveCan Music 22 22nd August 2008 04:21 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
